Old 02-11-2005, 06:53 PM
ryanb4614 ryanb4614 is offline
Send a message via AIM to ryanb4614
Re: need to fix
i just masked everything off i could get it off :| anyone know how i could get my cd player working again?
Old 02-12-2005, 09:53 AM
Re: need to fix
Did i use the wrong clear coat? I bought crystal clear, clear coat? Should i have got a high gloss one? To make it more shiny. On my other one the i did not need to paint i could see my reflection in it. This one i cant
Old 02-12-2005, 10:46 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Re: need to fix
You didn't need to clear coat it at all, all you ever need to do on the black exterior pieces is to use blue cutting gel till it's dull, then use 3M Foam pad finisher on a buffer or rag till its shined...It restores it back to new..We've done this on many of the winburned pieces on various trucks and it's come out perfect every time.
Old 02-12-2005, 10:51 AM
Re: need to fix
did u see the pictures it was a rough surface ? i had to be sanded
Old 02-12-2005, 10:54 AM
rlith's Avatar
Re: need to fix
Yes, I saw the pics... Very windburned... And even with sanding, (if you have a gouge) 2000 grit wet sanding then using the blue cutter then 3m foam pad finisher would achieve the same thing.
Old 02-12-2005, 12:46 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Re: need to fix
You do both of them. Not one, both.
You can NEVER match them up perfectly.
1995 Factory Blazer Service Manual for sale, PM if interested.
