Old 01-08-2005, 04:17 AM
PhantomDesign's Avatar
PhantomDesign PhantomDesign is offline
Send a message via AIM to PhantomDesign Send a message via MSN to PhantomDesign
Re: Re: Enigma III - Exotic Supercar Concept
Here are some more pictures...
Click Here for 800x600
Click Here for 1600x1200
Gryphon Automotive - Exotic Vehicle Design
www.GryphonAuto.com
Old 01-09-2005, 06:01 PM
CobraR2000's Avatar
CobraR2000 CobraR2000 is offline
Send a message via AIM to CobraR2000
I must admit, they are REALLY good man
1996 SVT Cobra Coupe
320 HP@ 5800RPM
DOHC 32 valve
BBK Cold Air Kit w/ 87mm MAF, March UD Pullies
My Snake
Old 01-10-2005, 03:10 AM
Thanks CobraR2000
By the way, I'm sure some of you know that I'm kind of a perfectionist when it comes to my work (especially if any of you were around when I was designing the Predator). I guess I'm not showing you the final version of the Enigma 3. I just had too many ideas of how to make it better and couldn't resist. This is going to be a lot of work, but I think it shouldn't take me too long & it's already looking better. "The best is yet to come?" I think so.
As you can see I scribbled on top of my own pictures . Well, I don't expect it to make a lot of sense, so I'll explain a little. The areas above the wheel-wells are a little pinched, so I'm increasing the volume a little (will give better reflections). As far as the hood, instead of a 2-hump system (humps above the wheel-wells) I'm doing a slight 3-hump system & increasing he volume. The spoiler sketch is crappy, so you'll just have to wait. I'm removing the rear lip, making the rear not as tall in the back & adding an effect to make the rear look significantly wider and less tall. I'm also significantly reducing the size of the "humps" behind the seats, which should help with visual proportions (not quite as much reduction as I show in the pictures). Lastly, I'm making the lights and lower vents a little wider & revising the other vents and adding a plate holder. I don't know if any of that made any sense, but I think you guys will enjoy the result.
www.GryphonAuto.com
Old 01-11-2005, 01:36 PM
streetracr32's Avatar
streetracr32 streetracr32 is offline
that is b e a utiful!!!
Old 01-11-2005, 07:32 PM
You got that right, ha ha. Thanks!
I've been making a MASSIVE of progress on the updates and I might actually be able to show the updates in a day or two. All I've got to say is that the version of the Enigma 3 you see now will look bland and flat next to my updated version. I’m loving the updates, but I think I’ll leave it as a surprise this time instead of showing progress images.
www.GryphonAuto.com
Old 01-17-2005, 03:03 AM
I made a lot of updates to the Enigma 3 design (most of them subtle), so version 2 is here! Check it out…
Click Image for 1600x1200
Click HERE for 800x600
Click HERE for 1600x1200
This was a Work-In-Progress image that I liked, but I scrapped the spoiler and changed the deck lid slightly…
Pictures of version 1 are still available HERE and I will add any new pictures of the Enigma 3 HERE.
www.GryphonAuto.com
