Old 12-07-2004, 05:32 PM   #31
Scale-Master
Scale-Master's Avatar
Thank you.
No plans to sell copies, I don't think anyone would be willing to pay me a fair price for my effort.
Plus you'd need the tires and they only are available from one kit that I know of and retail on it is about $430.00 U.S.
Although someone with a lathe could make the outer parts for the rim and make them fit other tires they may have...
Brief How-To:
I machined the center in 6061 billet aluminum, old school style, not CNC or CAD driven.
7 spokes, split and tapered, figure that into 360 degrees...
Took about 10 hours of machining time for the master center.
I made a silicone mold and cast copies in resin.
Except for the center, the rest of the wheel parts are all individually machined.
There are fronts and rears with different widths and offsets.
The valve cores move like real ones, just for fun.
The gray color is Tamiya Light Gunmetal. - Mark
Scale-Master is offline   Reply With Quote
Old 12-07-2004, 05:53 PM   #32
mike@af
Captain Over Engineer
mike@af's Avatar
Re: Blue Seven (Parts)
Wow, by hand. I'd love to make rims by using a manual mill, but I dont have any idea how I would make them so perfect. Im guessing you have a radial style rotate table?
-Mike
mike@af is offline   Reply With Quote
Old 12-07-2004, 05:59 PM   #33
Murray Kish
Getting Old...
Awesome!
PLEASE show us some 'in-progress' pics of the machining stuff. I'd love to learn more about the 'old school style'...
Murray
Murray Kish is offline   Reply With Quote
Old 12-07-2004, 06:10 PM   #34
willimo
Sweet, sweet tiny Hondas.
The valves "work?" Wow! Fancy work. Those are beautiful rims. What's the inside/outside diameter of those tires, if I may be so bold?
Old 12-07-2004, 06:18 PM   #35
Scale-Master
Well, they are 205/50R16 (F), and 225/50R16 (R) and it's 1/12 scale. Do you want to know the actual measurements of the bead and tread area diameters of the model tires?
Old 12-07-2004, 06:33 PM   #36
Hiroboy
www.hiroboy.com vendor
Hiroboy's Avatar
Love them wheels
Can we see a photo of your Lathe and Milling Machine setup Please?
Steve a.k.a. Hiroboy
Hiroboy is offline   Reply With Quote
Old 12-07-2004, 06:57 PM   #37
willimo
No, I trust Tamiya bits to be in proper scale.
Old 12-07-2004, 10:00 PM   #38
rx7king
rx7king's Avatar
holy shit
rx7king is offline   Reply With Quote
Old 12-08-2004, 09:03 AM   #39
_WIDE_LOAD_
_WIDE_LOAD_'s Avatar
Send a message via MSN to _WIDE_LOAD_
My name's Troy, use it if you like.
If you're a Buddist, you go to Tibet....If you're a speed freak you go to the Salt Flats
351 clevo....aussie muscle
_WIDE_LOAD_ is offline   Reply With Quote
Old 12-08-2004, 09:47 AM   #40
Okiemodelbuilder
Re: Finished Super Seven Wheels
Another masterpiece from the Scale Master!!!
Completed Pro Touring Projects
...the pro touring experts
Okiemodelbuilder is offline   Reply With Quote
Old 12-08-2004, 09:48 AM   #41
Scale-Master
Here are some in progress shots, captions below each picture:
The spokes and mounting holes have been cut on the mill using a rotary table and the facets have been cut into the face on the lathe.
The taper of the spokes have been cut in on the mill and the nearly finished part is being removed from the stock.
The primered parts are the resin copies of the aluminum master, the holes for the valve stems have been drilled in the outer part of the rims. All of what is shown in this frame was painted gunmetal. An additional polished aluminum trim ring makes up the outer side of the mounting bead and another machined (on the lathe) part makes up the inner rim and bead.
Old 12-08-2004, 10:18 AM   #42
GvEman
GvEman's Avatar
aswesome!!
Best Regards
Anton
GvEman is offline   Reply With Quote
Old 12-08-2004, 11:44 AM   #43
Murray Kish
Getting Old...
Thanks. Looks fun!!
Murray
Old 12-08-2004, 12:52 PM   #44
mike@af
mike@af's Avatar
Thanks for the pictures. Now I have an idea of what to do. Might I ask where you got the end mill?
-Mike
Old 12-08-2004, 01:06 PM   #45
bigfrit
bigfrit's Avatar
Very true to your screenname, I love it!
Great skill!
Olivier
