#31
Re: clunk upon acceleration
if its a clunk that can sometimes sound like a chirping of a tire, then its the driveshaft yoke.....get the updated yoke or grease the hell out of yours.....if it goes away, great, if not, then id start looking at rebuilding your rear end.
#32
Re: Re: clunk upon acceleration
Hello, It sounds like you've described the 'groan' or 'chirp' my 2001 Z71 makes (50k miles) after a full stop, then accelerating. From what I've read in the forum, changing the xfer case fluid (using the Blue Synthetic fluid) first might be a good start to getting rid of this noise. Thanks. |
#33
Anyone happen to know the TSB number for the nickle plated slip yoke? I printed out a numbered list but don't see anything that actually says "slip yoke".
Thanks |
#34
Did anyoe realize that "Tigga" the original postie didnt ever respond to any of your posts!!
thought that was kinda funny, anyway, carry on
#35
Sorry, I can't remember the tsb, but the part numbers for the nickel plated yokes are 12477702 for the 1500 series, and 1247704 for the 2500 series.
#36
I have a 2003 silverado with a 6 inch lift, 3 inch body lift, 315/70/17 tires. Okay I have a CHIRP noise kind of high pitch, this noise is observed when i take off from a stop. It does sound like its coming from the right rear end like the others. ALSO when i pull out of my garage and my back end drops on the slope i hear it then. Sooo what would i check, i thought the transmission mount would fix the problem but no luck, so change to the blue fluid? the nickel yoke? just grease the yoke? HELP Please.
#37
If you are getting a clunk on acceleration it is the slip yoke. You can either grease the pooh out of it, inside on the splines or replace it with a nickel plated slip yoke. DO THIS!! It will take care of the noise.
#38
I tend to disagree with the slip yoke theory. I greased and also have installed the reaquetball fix for the slip yoke. This fixed the "clunk" when shifting from park to drive and from drive to reverse. But I still get a sort slip and clunk when I excelerate from a stop. And it feels and sounds like it is coming from the rear diff.
