Go Back   Automotive Forums Car Chat > Toyota > Celica
Old 06-19-2005, 03:10 AM
91 Celica St 91 Celica St is offline
AF - Advisor
Re: Read if ur wondering about the 3sgte swap
i have no idea what your asking, re phrase that
keep in mind you can rebuiuld with 3sgte parts, the bore/stroke are identical in the 2 motors, but a general rule is never buy pistons before u rebuild, find out what block work has to be done (i.e. just honing or does it have to be bored) cuz if u buy stock pistons and they cant just hone the block ur s.o.l (unlesss u plan on pre buying like 40 over already)
Old 07-27-2005, 07:13 PM
49cent 49cent is offline
95 celica
does anybody know where i can find clear bumper lights for a 95 celica st without fog lights?? or do the 96-97 bumper lights work??
Old 07-29-2005, 11:28 AM
GTSStevo GTSStevo is offline
Send a message via AIM to GTSStevo
this may have already been said, but what about the ecu? do you have to do any other wiring for the swap?
Old 09-07-2005, 02:08 PM
7afe nitrous
does anyone know if would be safe to put a small shot of nitrous in a 95 celica st (7afe) with 40k miles on it???
Old 11-06-2005, 10:14 PM
goleafsgo_12 goleafsgo_12 is offline
Just to clarify, the 3sfe motor is the 1.6 that came in the alltrac celica gt, as well as the mr2 turbo? ANd if I were to swap it into a 91 celica gts it is recomended to get the trans with the motor, as it will all fit into the same arrangment in the car, correct?
Thanks, Ryan.
Old 11-12-2005, 01:29 AM
AF - Advisor
^id only reccomend nitrus only if you have ntohing else to do on your engine, turbo it, dont get that
and no the 3sfe is a 2.0 liter engine
why would you swap in an engine with less potential then the one you have in it?
Old 12-20-2005, 11:03 AM
short_bus_lover69 short_bus_lover69 is offline
Re: Read if ur wondering about the 3SGTE SWAP (admin make stickey, pm 4 details)
we are doing an engine swap out of a 1991 celica that originally had a 4afe and we are trying to put the 3sgte in but the top 2 motor mounts do not align. Is there a certin place where i can get the motor mounts to convert it over? please respond ASAP.
Old 12-23-2005, 01:18 AM
AF - Advisor
are you talking about the cam cover side and tranny mount
we grinded down the cam cover side
use the 3sgte tranny mounts the 4afe ones wont work
be more specific
Old 12-23-2005, 11:38 AM
Re: Re: Read if ur wondering about the 3sgte swap
on the upper motor mounts do we have to make custom brackets? we put the right cross member on so the bottom tranny mounts do line up but we are wondering about the upper motor mounts.
A.C.I. Speed & Sound
Sarasota FL (941)-955-1755
Old 01-05-2006, 12:07 AM
AF - Advisor
no the upper mounts from the 3sgte should work, there should be no fabrication necessary, the only thing that is scety is the mount on the cam cover side, sometimes it tends to hit the cam cover, you can just grind down some of the metal to take it off
pm me and well discuss this
Old 01-06-2006, 03:44 AM
bo nada bo nada is offline
swap from 3sge to 3sgte
hi
i am asking about the stock 3sge tranny ..will it be able to handle the 3sgte power and for how long..
cos i am in middle of the swap ,, i stop it all because of the tranny ..idont know what to do....
shall i fix the 3sge tranny or what????
pls help me to solve this...
Thanks for all
Old 01-08-2006, 09:48 PM
AF - Advisor
why dont u just use the 5sfe tranny, yes you can use the 3sge tranny but you gotta take the shift linkage out of ur 5sfe tranny and the speedo gear and swap it over
Old 01-21-2006, 11:37 AM
hi
thanks for replay ....
i fixed the 3sge tranny but with 3sgte clutch and presser
when i want to move the car big sound comming from the gear and the car moving slowly with encreasing sound..
we take the car up ..the tires moving with out that sound...
so shall i fix the 3sge clutch and presser..
plz help...
thanks
Old 01-25-2006, 08:30 PM
AF - Advisor
that usually means somethings not right...lol no real way to diagnose w out taking a look, is everything working correctly tho?
Old 02-08-2006, 04:23 AM
Toyotaguy101's Avatar
Toyotaguy101 Toyotaguy101 is offline
HEy guys i just did a swap on my auto 92 celica GT I put in a 5sfe from a 2001 camry and it rews quite fast on the freway BUt the brob is that before 95 car geting speed like mad but once it hits 95 it stalls for some reason it just dont want to go higher i can feel that car has alots power to puch further but its like something is holding it back.
If any one knows please give me a hint.
