Old 11-08-2004, 10:16 PM
chcknugget's Avatar
chcknugget chcknugget is offline
Send a message via AIM to chcknugget
Re: Spark Plug Gap!
I know, I know... I'm @94k miles right now and I want to replace the factory plugs... What would be the best way to get them out of there? I have an 8" and 10" socket extender with a little universal joint. Can I get the plug out (after removing the front wheel) with these tools? Or is the steering shaft relocation the way to go?
Old 11-08-2004, 10:21 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Spark Plug Gap!
I would get another universal elbow and of course the proper plug socket.
Do one side at a time and shoot right through the wheel well with the tire off and you shouldn't have any problem other than the driver's side middle which is a bitch, but doable.
Also, gap them properly and use antiseize compound on them when you are installing them so they will be easy to come out the next time.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 11-08-2004, 10:38 PM
chcknugget's Avatar
Re: Spark Plug Gap!
Yeah, I already got the right socket. Would one of those "wobble extensions" work better than the u-joint? I haven't found out the right trick to get my u joint to work smoothly. I also bought a permatix "tune-up" kit with dielectric grease and anti-sieze compound to make things go smoother.
Do you think I should replace the plug wires at the same time as the plugs?
Old 11-09-2004, 01:11 AM
BlazerLT's Avatar
AF -Advisor
Re: Spark Plug Gap!
What year is yours?
Old 11-09-2004, 10:23 AM
chcknugget's Avatar
Re: Spark Plug Gap!
a 96
Old 11-09-2004, 03:57 PM
BlazerLT's Avatar
AF -Advisor
Re: Spark Plug Gap!
Hmmm......
You might want to but what is more important is the cap and rotor.
Old 11-09-2004, 04:09 PM
chcknugget's Avatar
Re: Spark Plug Gap!
where would you buy those? Ebay? It seems like you've already done the replacement.
Old 11-09-2004, 04:12 PM
BlazerLT's Avatar
AF -Advisor
Re: Spark Plug Gap!
The cap and rotor I would buy at the local parts store.
Old 11-09-2004, 08:40 PM
movin2stereo's Avatar
movin2stereo movin2stereo is offline
Re: Re: Spark Plug Gap!
Originally Posted by BlazerLT
All Bosch Plats are junk, don't use them.
The AC Delco plats can be gapped if not properly gapped from the package.
Son of a bitch! That figures,now I am going to have to change them.I have noticed that it hesitates a bit.I didn't think it was the plugs (Bosch platium +4s)though,they are brand new.
Stickerchick.com,best decals on the net
Click here
My $12.00 Sunfire
Old 11-09-2004, 08:55 PM
BlazerLT's Avatar
AF -Advisor
Re: Spark Plug Gap!
Yea, they are never good.
Also, make sure your MAF sensor wires are clean.
Old 11-09-2004, 09:17 PM
Re: Spark Plug Gap!
For the MAF.What do mean buy make sure the wires are clean?Do you mean where it plugs in or the screen lookin mesh?
Click here
My $12.00 Sunfire
Old 11-09-2004, 10:56 PM
BlazerLT's Avatar
AF -Advisor
Re: Spark Plug Gap!
There should be wires inside protected by the steel mesh and the wires sometimes get gunked up.
This can cause some hesitation.
If there is a lot of black crud on them, spray brake cleaners through the MAF screen to dissolve the deposits on it.
Old 11-10-2004, 08:18 AM
Fireplug Fireplug is offline
Re: Spark Plug Gap!
I would NOT use brake cleaner USE carb cleaner that o2 save. I dont think brake cleaner is 02 save
Old 11-10-2004, 01:20 PM
BlazerLT's Avatar
AF -Advisor
Re: Spark Plug Gap!
I am saying with the MAF sensor removed. Not installed on the engine.
Old 11-10-2004, 06:54 PM
atomicpulse's Avatar
atomicpulse atomicpulse is offline
Re: Spark Plug Gap!
can you use throttle body cleaner to clean the wire in the MAF sensor?
