#31
Re: Blower Motor Resistor Replacement (with pics)
So happy to find this post !!!! Does anyone knows if it's the same location for a '99 Intrepid ?
#32
Still looking for location and instructions for the 99 Sebring. Any help is appreciated
#33
I know this is an old thread, but yet it is still revelant.
It needs to be stickied up to the top for easy viewing.
I also thought would let you know that I found that part at our local carquest for under $20.
Hahaha I concur. I even remember the day I was doing it, and decided to come here... Wow that was a long time ago.
"The thinner the TV, the better the TV, it's just straight up fact." -Dennis |
#36
Thanks so much....I was able to change the resistor for my 2001 Stratus. I'm pretty proud of myself. When I told my boyfriend that I was going to try to fix it, he said "Good Luck". It took less then an hour. It would have been faster if I could have found an 8mm socket, but it was know where to be found. Instead I used a pair of pliers, it worked but took a while. When you seperate the resistor from the block I fould it easy if you pry the red "?clippy?" thing up, then push the blue "?clippy?" things on both sides. It came of easily. I used and exacto knife to make the hole bigger. I cut the hole up to the line in the plastic. When you put it back together don't forget that the red "?clippy?" thing is on the top side, where you can't see it. The part was under $46 from the dealer. I'm so stoked that it works. Thanks again everyone for all the info.
#37
Thank for all the info. I was able to fix my 2001 Stratus for under $46 and in less then an hour.
#38
Hello,
I have all the symptoms you all have regarding the blower... except my 4 / high setting doesn't work either. It seems to be stuck on 1 or just vent if anything. I have a 2003 Chrysler Sebring V4. I took it in to the repair place today... and they determined that it was the "Blower Motor Resistor". They told me it would be $90 and they couldn't find a part anytime soon... So I called a dealer and they said that the part would take 2 days but it is really easy to replace (just like you all say here). So I told the repair shop I would take my car and get the part from the dealer. The repair shop insists it will be hard and will have to go the the glove box... ANYWAY... Does anyone have an opinion regarding my problem being that I need a blower motor resister, that is if my 4 setting also doesn't work? I am concerned that I am going to buy this part, install it... and find that it doesn't fix my problem. |
#39
Seabring o4 the problem continues used the picks and info took about 45 minutes and had it back toghter and working wow thanks.
#41
Hello,
Thanks to this site and to the advice from those that replied, my 2000 Sebring Convt. also had the blower motor resister go out. Following the instructions posted, I was able to remove the part and purchased a new one for $27. Fitting under the dash, as others have posted was the hardest thing. |
#42
Ok, I have a 2000 Sebring Convertible and it has the problem posted where it only works on high. I ordered the replacement part on the pictures but when I removed the old one it looked like something out of a mad scientists lab. Did I get the wrong part? Can I use the flat credit card resistor that I bought or do I have to look for the caged, blob thing? I thought that this was going to be easier but now all I have accomplished it a pounding headache.
Thanks
#43
Thanks All! I just replaced the cage resistor on my 99 Sebring. It took 20 mins and 22.00 US.
Thanks Again. |
#44
Thanks you made it easy...none in stock but 5 day order from NAPA for $37, was 48 at Carquest. Thanks again!
#45
Thanks you made it easy...none in stock but 5 day order from NAPA for $37, was 48 at Carquest. Thanks again! O2 Sebring convertible LXI
