Originally Posted by edman24
powershifting in my circles is when you shift without using the clutch. at certain points in the rev range the gears will mesh together perfectly and the tranny will actually go into the desired gear without grinding. but this is extremely difficult to do correctly and very easy to f*ck up. you wont know at what rpm either until you try it and that would put immense amounts of wear on the tranny. although it might be slightly faster it is totally not worth the risk.
LMAO...ok here is an experament for you...go get a car with a newer transmission....get going in 1st, then with out pushing the cluth in try and yank it out of gear into neural....isnt going to happen.... power shifting is not letting off the gas between gears, a good way to screw the tranny and engine along wiht in lower gear get rid of that anoying tread...double clutching is how you have to shift in older, or non syncro trannies....you basicly push the clutch in, take it out of gear (neutral) let revs drop if shifting up, bring them up if shifting down, then push the clutch in and go into gear....power shifting is actually a great way to induce oversteer in a corner (drifting) and so is engine braking... oh and for thoes of you who dont know what engine braking is it when you are in say 5th, then you want to slow down so you push the clutch in, let the revs drop in neutral, then shift into a lower gear (ie 3rd or 4th) and then slowly let out the clutch....dont drop the clutch because your wheels will not completely lock up but will get very close and you engine revs will jump from idle to redline or higher in a matter of seconds...not good any anything mechanical on your car....
