Old 08-16-2004, 04:56 AM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Re: Disabling Cylinders
There is no 'easier' for the engine to suck in more air. The engine is going to create a vacuum and suck in air. If it sucks in less, with a stock filter, then you are going to get less fuel usage and also less power.
Old 08-16-2004, 05:12 AM
george536's Avatar
george536 george536 is offline
I put a short ram on my gs and i got better gas milege, but when i got an exhaust it felt ilost gas milege. so i dont noe...
-1997 Eclipse Spyder GST |Stock|
-1990 Eclipse GSX
|ACL Main & Rod Race Bearings|Balance Shafts Removed|ARP Head Studs|Cometic HG|FP 20g TDO6H|EPROM Chipped (stutter box 5k, fuel comp.)|PTE 680cc inj.|Walbro 255 HP Fuel Pump|Autoteq FPR|SAFC 2|FMIC|2g MAF|Dejon Tool Hard Pipe|Greddy Type S|MBC at 17PSI|Ported 2g Exhaust Manifold|02 Housing w/ Tial 38mm WG|Full 3inch Exhaust w/ Y-pipe Cutout|Fidanza Flywheel|ACT 2100|4 Bolt LSD Rear|Poly Mounts|KYB AGX Suspension|Roll Bar|
Old 08-16-2004, 05:16 AM
JoeWagon's Avatar
Banned
well i get no better sleep at night if people don't agree with me, but at least they know my thoughts. If anyone wants to keep going with the thread, bring some proof or just leave it to be that driving has a lot to do with milage, and disabling cylinders is not a good way to do it!
Old 08-16-2004, 11:43 AM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
I still believe a intake does improve gas mileage, but on my car a exhaust did not help it the gas mileage went down..
This says that they both do.. so who knows..
"Lots of other performance products can improve an engine's performance and fuel economy, too, including a high-flow intake system and a free-flowing exhaust. It's easy to understand why improvements to the intake system help: If you've ever tried drinking a really thick milkshake through a straw, you know how hard it can be to pull that fluid through an opening that's too restrictive. Your engine may be feeling the same way about incoming air.Exhaust system changes work pretty much the same way: If your engine is trying to force its spent gases out through an opening that's too small, it's wasting energy. Plus, if there's too much backpressure, some exhaust may remain inside your engine, which means there isn't as much room for fresh air and fuel to be burned, so you're making less power."
~http://www.enjoythedrive.com/content/?id=7021
Another site:
http://www.carjunky.com/news/newtext/40e.shtml
For Sale 98 Eclipse GS, 5 spd
Old 08-16-2004, 05:38 PM
rodknock rodknock is offline
Send a message via AIM to rodknock
best way to save on gas is to walk <words of wisdom>
