Go Back   Automotive Forums Car Chat > Nissan > Almera | Sunny | Pulsar | Bluebird | Tiida | Versa | NX | Avenir | Tino | Stanza
Old 03-11-2010, 03:43 AM
Audigrl Audigrl is offline
Re: How to program a remote key Fob?
does any one know how to reprogram a remote key for a 1998 audi a4 quatto??? it seemed like the battery was dying cuz i would hit the lock button on the remote and it would some times work an then stopped working all together. i replaced the battery in my remote but it still wont unlock/lock my car with my remote. PLEASE HELP!
Old 04-10-2010, 01:38 PM
rlarson rlarson is offline
This worked on my 2000 maxima
IMPORTANT: Before entering programming mode, have in possession all of the transmitters you will be using on the vehicle. Once you program the transmitter, all previous codes will be erased from the memory. The other transmitters will not be functional until you program the transmitters again.
1.Close and lock all doors with the driver’s side power lock/unlock switch.
2.Insert key into ignition and remove it from the ignition key cylinder at least six times within 10 seconds. Your Hazard
Lamps will flash if you have performed this step successfully. NOTE: Withdraw key completely from ignition cylinder
each time. If this procedure is performed too fast, system will not enter programming mode.
3.Insert key into the ignition cylinder and turn to the ACC position.
4.Within 5 seconds, push ANY button on the remote transmitter. Your Hazard Lamps should flash. NOTE: Do not press
the button more than one time in the above step. If the button is pressed more than one time, the programming
procedure will not be successful.
5.If there are any remaining transmitters (including the old ones), unlock then lock all doors using the driver’s side
power lock/unlock switch and within 5 seconds, push ANY button on the next remote. Your Hazard Lamps should
flash. Repeat this step for each transmitter (including any existing transmitters).
6.Turn the key to the OFF position, remove keys from the ignition, unlock doors using the driver’s side power lock/unlock switch and open the driver side door.
Old 04-23-2010, 03:14 PM
SHAWN KOBUKE SHAWN KOBUKE is offline
Thumbs up Re: How to program a remote key Fob?
Thanks for the great info!
I was able to reprogram my remote in one try! My husband thinks I'm a genius!
Old 12-23-2011, 11:45 AM
carl.odle carl.odle is offline
I have a 2010 Nissan Altima and a pocket full of keys plus a fob for starting/entering vehical/etc.
Could I buy a key with a embedded transponder that could be programmed to allow me the same results and give me some room in my pocket again??
Thanks for any help provided...
Old 01-04-2012, 10:47 AM
carl.odle
1-4-2012, 11:50 AM
Old 03-09-2012, 11:23 PM
yannick yannick is offline
Hi, i have a nissan versa 2007 model S 1.8 hatchback. I bought it used and it came with remote control. The remote works only to start the car. The lock and unlock button does not work it only makes the lights flash on the car... i tryed to program the remote as mentionned in this forum but it does not seem to enter programming mode. The car is basic no power lock. To get in the trunk i have to unlock my front door, anyways can i program this type of car model? Or else what can i do? Thanks for any help
Old 05-21-2012, 01:19 AM
JayJan JayJan is offline
Hi Yannick, you can find instructions to program the remote for your Versa on the site http://programcarremotes.com
I think the link to your particular model is 2009 Nissan Versa
Let me know if that works or not and I will try to dig up something else that works.
Old 08-01-2012, 08:08 PM
Onblsht's Avatar
Onblsht Onblsht is offline
Authorized Vendor
Do you have the base remote or smart key remote for your Versa as shown here?
http://originalkeyless.com/searchqui...%2207+Versa%22
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
Old 11-10-2013, 11:59 AM
autoexpert2 autoexpert2 is offline
Hi
You can program yourself.
Just follow simple instructions.
http://programkeyfob.com/nissan/nissan.html
