#31
Re: What is the biggest tire I can put on a STOCK 98 Tahoe?
Just go with 285s
911 Super Targa RSR [Dual Flow Intake][Twin Turbo][Larger List to Come] |
#32
Re: Re: What is the biggest tire I can put on a STOCK 98 Tahoe?
oh yeah, for you guys bent on going to a taller tire/larger diameter and wider tire (as opposed to a just wider tire with shorter sidewall to maintain the same tire diameter) - when you move to a larger diameter tire, you are going to lose some acceleration, esp. at lower speeds/standstill (although, if your engine has the power, you will have a higher maximum MPH) due to the tires playing an important role in final drive ratio, along with most importantly your ring and pinion gears (ie: 3.73:1, 4.11:1, etc)
#34
This is true, significantly larger tires can require a new rear end with a higher ratio. However, small increases in diameter actually serve to increase highway gas mileage to an extent.
#35
Just thought I'de let You guys know I ended up going with 265/75R16 BFGoodrich Allterain T/A KO's THEY RIDE REALY NICE
Bart 98 Tahoe LT K&N Drop in Air Filter Rancho 5000 Shocks all around 265/75R16 BFGoodrich Allterain T/A KO Tires WHELEN 9600 Series, 10 Strobe, Light Bar with Smart Messenger ALPINE CDA-9835 CD/MP3 Player My Ride
#36
pics?
#37
I have not read through all the posts, so I do not know if this has been mentioned, however if you go to a larger tire, you will have to make a tire diameter change in the PCM to correct the speedometer, for the PCM uses the MAF readings AND the speedometer readings to shift the automatic transmission.
