Old 11-21-2007, 02:42 AM
Krazy Jeff's Avatar
Krazy Jeff Krazy Jeff is offline
Re: What makes speakers scratchy when music's loud???
I am not sure if this could help someone, but recently I was having issues with the left 5 1/4 two-way speaker on the dash on my van. It would have a scratchy sound, like if the tweeter was dying. I then inspected the speaker and found that one wire that goes from the woofer to the tweeter was not soldered 100%. The wire seems to be made of an elastic type of ribbon wire. So I grabbed my solder gun and soldered the wire to the tweeter. Now it doesn't have that scratchy sound anymore.
I think the scratchy sound I was hearing is while the woofer was moving, it would cause the tweeter's loose wire to intermit on/off. Hopefully this helps.
1997 Plymouth Voyager; SWB; 2.4L 4cyl.
  • Pioneer DEH-P6900UB (Head Unit)
  • Pioneer CD-IB100II (Adapter 4th G 60GB iPod)
  • Bazooka BTA10200 (10" 200W Powered Sub)
  • PNY 4GB USB Flash Memory (USB music source)
  • TomTom One LE (GPS)
Old 11-21-2007, 05:50 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
the wire from the speaker frame to the cone is made of braided wire to make it flexible. You'r lucky you didn't burn the voice coil when you soldered the wire
Old 11-21-2007, 09:10 PM
Krazy Jeff's Avatar
I guess I was lucky. I do have experience soldering delicate equipment. So I was careful to not use more than 20 watts to solder the piece together. It really didn't need that much heat. Nor did I need to keep the solder gun tip too long on the connector. It was such a simply process, and now the tweeter doesn't rasp as the woofer moves.
Old 03-30-2009, 09:52 AM
lowrider gangster lowrider gangster is offline
it depends wat u got and it depends on wat kind of amp u got i got 2 15 and a 500 watt amp it beat like crazy
Old 03-30-2009, 10:07 PM
AWP9521 AWP9521 is offline
Hmm, conversation died on this thread a few years back.
Originally Posted by AWP9521 - 02/16/2005
Sure sex is a thrill too, but your modified car will never tell you
"Sorry honey, I just don't feel like it tonight" it will always be in
the garage silently waiting for you to hop in so it can thrill you
some more, that is unless you break it. At least they're easier
to repair and get the thrill back than a pissed off girlfriend.
