Go Back   Automotive Forums .com Car Chat > Isuzu > Rodeo | Passport | MU
Old 06-04-2006, 02:38 PM   #31
surferfletch
Re: 2000 Rodeo 4WD LS transmission leak
Can someone take a picture of this accumulator cover, please?
surferfletch is offline   Reply With Quote
Old 06-04-2006, 05:21 PM   #32
amigo-2k
Isuzu Guy
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
amigo-2k is offline   Reply With Quote
Old 06-05-2006, 04:28 PM   #33
surferfletch
Thanks!
Old 11-22-2007, 01:14 AM   #34
Kentoxboy
Originally Posted by amigo-2k
The picture isn't working anymore.
Kentoxboy is offline   Reply With Quote
Old 11-22-2007, 09:28 AM   #35
FL 3.2L
It's on the pasenger side of the tranny toward the front. It is round and held in by a snap ring. It about 2" in diameter, I think.
'97 Rodeo LS 4X2 Dueler Alenzas 4L-30E 200K
'96 Jetta 249K
'97 TJ 156K
'02 VW Cabrio 70K
'03 E46 107K
FL 3.2L is offline   Reply With Quote
Old 11-22-2007, 10:43 PM   #36
Kentoxboy
I had that problem "the leaking" last week and I am trying to look for a write-up on how to fix this. I look at those diargrams but I don't have those tools to fix it. Has anyone find a easy way/tools to fix it? or a simple write-up?
Thanks
Ken
Old 11-23-2007, 07:59 PM   #37
FL 3.2L
You have to push in on the middle of the cover as you release the snap ring with some snap ring pliers (super cheap at any parts or tool store). If the cover doesn't pop out, you can start the truck briefly and the pressure will push it out. Use a crow bar or something similar to apply pressure.
'96 Jetta 249K
'97 TJ 156K
'02 VW Cabrio 70K
'03 E46 107K
Old 12-01-2007, 05:12 PM   #38
Kentoxboy
This morning I tried 4 hrs just to figure out how to push the cover in... I tired many different ways, but no luck. I saw that there is a special tool that I need in order to put the spring in. Has anyone try to push the cover in by using a simple tool (that I can buy it cheap) other than a special tool?
Old 12-01-2007, 05:57 PM   #39
FL 3.2L
http://www.automotiveforums.com/vbul...ht=accumulator
2eyefishclaw claims he can do one before you can drink a beer.
Let me see if I can find another post... Did you get the snap ring out?
'96 Jetta 249K
'97 TJ 156K
'02 VW Cabrio 70K
'03 E46 107K
Old 12-01-2007, 06:00 PM   #40
FL 3.2L
http://www.automotiveforums.com/vbul...ghlight=piston
Here it is. And don't hate 2eye for doing in 15 minutes what you couldn't do in 4 hours!
'96 Jetta 249K
'97 TJ 156K
'02 VW Cabrio 70K
'03 E46 107K
Old 12-01-2007, 06:30 PM   #41
Kentoxboy
I couldn't even push the piston in because the spring behind it is too strong.
Old 05-06-2008, 06:53 PM   #42
BB_Mike
I am doing this fix now, based on the info from this thread.
I can not get the original accumulator cover out! the car has ran for at least 15 minutes and it hasn't budged. yes, the snap ring is out.
edit - I let the trans get into 3rd gear after putting the rear axle on jack stands. As soon it it hit 3rd gear, I heard a "pop". I shut off the car and slowly took it back to being stopped. Didn't want to jam on the brakes. The accumulator cover had come out! The spring was outside of the garage, and the accumulator piston thingy was on the floor near the transmission. Another option is to press the WINTER button on your center console. This should force the trans' into 3rd gear, which means you don't have to lift the rear wheels. Totally not proven though.
I'd recomend putting a piece of wood up between the transmission and the driveshaft to control that springs energy some.
Also, I used a really long breaker bar to put in the new cover. I put at smaller ~9/16" socket in like suggested above. using the frot driveshaft as the pivot, I got enough force to press it in. I'm a bit of a weakling (~150 bench press) so I had to put my leg on the frame. Once the cover was in, I didn't need to multi-task and get the clip in at the same time. I remove the lever/bar and the cover stayed in place while I got the snap ring ready.
BB_Mike is offline   Reply With Quote
Old 05-06-2008, 10:23 PM   #43
BB_Mike
Also,
I am doing the transmission filter at the same time. Taking down the cross member and trans' mount took all of 30 minutes. I used a jack stand to support the Transfer case.
Thanks again for the insite guys!
Would someone mind sending this thread on to the FAQ creators so that the "3rd gear is needed to pop out the cover" tidbit can be included.
Thanks! Next step is to fix the detonation.
Old 11-13-2015, 06:39 PM   #44
gimmini000
have same prb on my 2000 i no how to replace it but can anyone tell me were i can order the parts cant seem to find them
gimmini000 is offline   Reply With Quote
Old 11-13-2015, 10:19 PM   #45
BB_Mike
The transmission is a 4l30e.
The part in question is the Accumulator Piston.
the seals for it can be called o-rings, gaskets, or repair kit.
Here is another jnfo source with some oem type part number to help with searching. Scroll down to the all CAPS post.
http://www.4x4wire.com/forums/ubbthr...te_id/1#import
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 06:32 AM
