Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 12-12-2006, 06:46 PM
skier-24 skier-24 is offline
Re: How to program my keyless entry??
If you are so smart and experienced, why doesn't it work?
I bet both of you still get your lunch money stolen on a daily basis.
Old 12-12-2006, 08:53 PM
rodbls's Avatar
rodbls rodbls is offline
Send a message via AIM to rodbls
We are both so smart and experienced that when things dont work out like we expect them to, we stop worrying about it and have SOMEONE ELSE deal with it.
Chances are that the remote you have isnt working with your car because it's the WRONG REMOTE! Like we said previously...go to the dealer and they will be able to fix it. Will you get raped out your ass...more than likely. Will it fix the problem...YES!
Also...I'm older than, lets say 8, so having my lunch money stollen is far from my list of possible concerns. Go back to your mother to change your diaper because judging by the way you are acting, you have soiled yourself and need someone to wipe your ass and have them tell you it's special and better than everyone elses.
I guess I will throw a better zinger at you than the lunch money BS...here I go.
I bet you are such a bitch that you get bent over, and fucked in the ass on a daily basis...AND LIKE IT!
2000 Fed. Spec GT-"Lafawnduh"
Mods: SPEC 2+ Clutch, Fidanza Flywheel, PowerStop Rotors, Red Stuff Pads, Stainless Brake Lines, B&M Short Shifter, Energy Suspension Shifter Bushings, Deyeme Firm Motor Mounts, KYB AGX shocks with Eibach Proline springs, Halo Projector Headlights with HID 12000K Conversion, TYC Carbon Tails, Kicker SS6.5 Component Front, SS MB8 Custom rear, Tsunami 2F Capacitor, ***New Stuff*** JVC KD-AV7010 In Dash DVD Player, Kicker L7 12" Woofer, Kenwood KAC-X10D Mono Amp
Old 12-13-2006, 01:45 PM
Sleepr awd's Avatar
Sleepr awd Sleepr awd is offline
Send a message via AIM to Sleepr awd Send a message via Yahoo to Sleepr awd
Originally Posted by Elchicoloco86
...because either the procedure is faulty, the user is faulty, or the hardware is faulty. in any case, you won't be able to do it, but they will be able to.
i just told you why, pick any of the above reasons.
i'm going to go with it being user error though, because if you missed that, you can't read.
And i steal the lunch money.
Old 12-13-2006, 02:34 PM
808drifter 808drifter is offline
and pays me the lunch money to make faulty remotes
Old 08-22-2008, 09:39 PM
Scapeclipse Scapeclipse is offline
I tried this steps but my for some reason i can't make to work. same car and yes can any body please help me out Thanks!
Old 12-04-2008, 04:02 PM
rcglfr rcglfr is offline
Originally Posted by Sleepr awd
you have to understand i deal with incompetent people at work all day. And this, many times, is a continuation with that. If you can't figure it out, grow some balls and go to the dealership, because they can do it in little to no time at all. Is it worth the 45 dollars to you to spend 4-5 hours on trying to figure it out, when you can just spend the 45 dollars or so and have that time to spend doing more productive and useful things??
i would think so, i dont' waste my time trying to figure out things when i can be spending time doing things i enjoy doing. So, if you've read teh ENTIRE thread, and followed everything, then all you need to do is go to the dealership and have them figure it out, because either the procedure is faulty, the user is faulty, or the hardware is faulty. in any case, you won't be able to do it, but they will be able to.
SLEEPER, You are an a**hole. I don't give a crap if you deal with incompetent people all day or not, if you don't want to be bothered then DON'T READ THESE POSTS! This forum is not the place for your rude and insulting remarks!
Old 03-30-2013, 01:11 PM
dtm2000 dtm2000 is offline
I have a 2003 Mitsubishi Eclipse Spyder GTS. Just wanted to add that the instructions posted by kiger work fine except I had to have the key in the accessory position and not the off/lock position ... Then it worked.
Also you need to reprogram all your remotes. I bought 2 new ones, went through the procedure to program the 2 new ones and then the original did not work. So I repeated the procedure again for all three remotes and all were good.
There are other sites that have instructions also which you can google for. The one below also had a good pic of the pin-outs for the connector so you can make sure you jump the right pins. As kiger posted, if you use 2 big paper clips, one in each pin hole (1 and 4) and then touch them together after you turn the key in the ignition it works well and you can do it while sitting at the wheel instead of having to lay on the floor, i.e put the paper clips in the pin holes, sit in front of the wheel, put the key in and turn, touch and hold the clips together and then press the hazzard button 6 times, etc.
http://www.programyourremote.com/cla...yAd.asp?id=966
Old 03-30-2013, 01:18 PM
Also, I think after programming the new ones did not work until I turned the key to the off position and then started the car ... Or at least put the key in the on position. I'd have to try again to verify that though.
Old 08-12-2015, 10:43 PM
Bullet67 Bullet67 is offline
Question. Programming went smoothly but does the horn not chit on activation and seems the alarm does not activate. Is this normal? Thanks.
