Go Back   Automotive Forums .com Car Chat > Racing > Street Racing
Old 11-16-2003, 12:23 AM   #31
youngvr4
STREET RACING GURU
youngvr4's Avatar
yeah i think that goes for a lot of other people too, they over rate there hp, hell i might be over rating my hp also. i'm not really rating it but just my assumption is probably over rated.
youngvr4 is offline   Reply With Quote
Old 11-16-2003, 05:27 PM   #32
98MitsuTurbo
98MitsuTurbo's Avatar
Send a message via MSN to 98MitsuTurbo
Re: 3000gt vr4 vs Supra turbo
Ummm. For all those who dont know, a VR4 with 320hp and all whell drive will school a mk4 Supra . The supra is only 200lbs lighter than a VR4 so its o compitition rilly. Ive raced many mk4's and schooled em all
Tim
**1998 Mitsubishi 3000GT VR4**
98MitsuTurbo is offline   Reply With Quote
Old 11-16-2003, 05:34 PM   #33
92teggsr
Re: Re: 3000gt vr4 vs Supra turbo
Tim
if you're talking about the 93+ then yes you will probably school a non-turbo but a turbo supra will walk away from you every time stock for stock.
99 Honda Civic Si
Stage 2 Clutch
SPP Exhaust
Short Shifter
Eibach Suspension
17's
91 Honda Accord LX
92teggsr is offline   Reply With Quote
Old 11-16-2003, 09:49 PM   #34
98MitsuTurbo
im talking about my 1998 Mitsubish 3000 GT VR4 STOCK vs, a 1997 Toyota Supra TT STOCK. I have 320hp & AWD vs. 320hp & RWD. Im sorry but i win
I have raced countless STOCK supras when my 3kgt was stock and i won. i also have driven and even owned a 1995 Supra TT and the 3kgt is quicker than it.
Tim
Old 11-16-2003, 09:53 PM   #35
youngvr4
STREET RACING GURU
youngvr4's Avatar
got a little quite in here, hello, hello
Old 11-16-2003, 10:25 PM   #36
Amish_kid
Amish_kid's Avatar
Tim
Real men race from a roll. Ha well I'd say just about everytime you'd beat a Supra from a dig but not from a roll considering it has a higher top speed. And a suspension set-up thats not really made to go from a dig.
Amish_kid is offline   Reply With Quote
Old 11-16-2003, 11:12 PM   #37
-The Stig-
On Fire!
-The Stig-'s Avatar
Send a message via AIM to -The Stig-
Re: Re: Re: 3000gt vr4 vs Supra turbo
That's why you get Konig adjustables... it'll save you 2lbs and give you better traction for the hole shot...
2003 Chevy 1500HD - Hauler
1971 Chevy Camaro RS - Track Car
User Guidelines It's important to read, like the Bible. But unlike the Bible we will strike you down if you jerk off around here.
-The Stig- is offline   Reply With Quote
Old 11-16-2003, 11:12 PM   #38
2000LS1Z28
98 Mitsubishi turbo, anything can happen on the street. From a roll a Supra should mertlize you. Of course from a dig the cars are very equal. Im surprised that you found a stock MKIV supra personally. Almost everyone of them out there is a BPU. Heck i'd race you, but I think you live rather far away from California.
2000LS1Z28 is offline   Reply With Quote
Old 11-16-2003, 11:26 PM   #39
Amish_kid
Amish_kid's Avatar
Re: Re: Re: Re: 3000gt vr4 vs Supra turbo
Even with new and better suspension parts the Supra will always be slower from a dig not to say the car itself is slow but 60' times in Supra's are kinda funny.
Old 11-16-2003, 11:41 PM   #40
98MitsuTurbo
Umm If anyone doughts my abbilitie to kill a supra i would welcome the challange. I warn you now my 3000gt isnt stock anylonger, pushing 725 and got 150shot wet direct port. So ya, plz let me know if you would like to raise the supra vs me question il gladly answer it for you
Tim
Old 11-16-2003, 11:54 PM   #41
fatninja19
Send a message via AIM to fatninja19
Re: Re: Re: Re: Re: 3000gt vr4 vs Supra turbo
Nah dude, the kid that shoulda went to MIT but didn't cuz of his ADD said so. He even showed me on his computer.
when in doubt, throttle.
fatninja19 is offline   Reply With Quote
Old 11-17-2003, 12:06 AM   #42
fatninja19
In a different thread, you said that you pulled 13.9X 1/4 mile times when you were stock. I doubt that time is good enough to pull on MKIV Turbo Supras....
Old 11-17-2003, 12:11 AM   #43
98MitsuTurbo
ya stock i did a 13.9 with a bad clutch and i was 17 Dude i have done it a bit more and am a BIT better at it not. My 3000GT VR4 has 725 hp now, and is HEAVLY modifiedFor engine mods im running HKS Twin Super Sequential blow off vavles, HKS Electronic Valve Controler,JET performance ecu(custom application), twin HKS intercoolers(also custom made), custom bent intercooler piping, 150 shot NOS (direct port), HKS MT-i wiring harness(for turbo timer), Twin HKS TD04L (13G-6) turbos (rebuilt for application), custom made hi flow fuel pump,hi flow BOSCHE fuel filter, 825cc injectors, hi outpur BOSCHE coil, NGK 8.5mm wires, HKS 6G72BT Iridum spark plugs, HKS SMF intake system,UNORTHODOX Ultra G - Performance Clutch Kit With Flywheel and Dual Disc Stage 3 Turbo only (Pinned for race), CENTERFORCE release bearing, custom made triple core rad, CUSCO rear uper strut bar, modified HKS Hipermax DRAG Coilovers, custom camber plates, custum byas diferential, and ill have to try to remember the rest. Ther was alot of time and money put into thins car. I did it all ar KRANGLES. Alot of custom fabrication went on in this car.
And thats the stuff i can think of now i always forget something. But ya im shur i could pull a low 13 hig 12 if it were still stock now
Tim
Old 11-17-2003, 01:36 AM   #44
2000LS1Z28
No offense but that doesn't appear to be big enough turbos for 725 awhp. Do you have a dyno slip to prove this?
Old 11-17-2003, 01:50 AM   #45
98MitsuTurbo
Your right The original turbos werent big enough to handle that much power. But you see i live in a city where there are alot of shops that do custome work. The only part of that turbo that is actualy the original HKS TD04L (13G-6) is the outer casing, the rest has been changed ie, compressor wheel , compressor wheel nut, journal bearings, thrust collar, o rings, carbon seal, lockplates, shaft nuts, bearing housing and turbine shaft. I find it just to hard to say all that so i tell you what i was
But i fouy lik wi will get the printoff from my shop. I have a 4 wheel dyno and i did it myself but i would gladly. And if anyone in the Vancouver Canada area wonts to put there 3000GT on a dyno PM me and you can come by the shop.
O and no offense taken, i understand, cant accept something if ther is no profe
Tim
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 06:32 AM
