| Search | Car Forums | Gallery | Articles | Helper | Quality Dog Food | IgorSushko.com | Corporate |
| Latest | 0 Rplys |
| Performance Discussion about performance modifications and issues. |
Show Printable Version | Email this Page |
#31 | |
Re: How much power do you have?
I am a Mustang guy, so I know those mods very well
![]() I am going to set mine up the same as your, except I will be going with a little higher comp ratio. Everything you have done to your GTR, to me, is the right thing to do, but I am not sure if I would go that high of a duration. I would be looking at 256/9.1 260/9.1, unless you really like the idle, and drivability of the 2 260s?
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper. |
#32 | |
![]() Join Date: Jan 2002
Re: Re: How much power do you have?
SkylineUSA,
The Tomei 260degree cams are very drivable, the idle is just a nice touch, the low speed vacume is still pretty decent giving the car a stock like low speed character. The Tomei cams also retain the same factory stock base circle and in most cases don't need any shims (mine didn't) and the 9.15mm lift is the largest lift cam you can fit without machining the head. Some of the other brands only go as high as 8.7mm. I did my homework on the cams before rolling my car into the shed to change them and for a street / circuit car these are the pick of the crop. As an example a freind of mine over here in Perth fitted them to his car, he has 2530 sized hiflows and picked up around 100hp over factory cams playing with the cam timing. I think he ended up with about 8 and 10degrees advance on them. His end figure was 527rwhp (dyno dynamics) on our premium pump fuel at 1.3bar. Last edited by tazdev; 09-30-2005 at 06:46 PM. |
#33 | ||
I'm still here
![]() Join Date: Nov 2001
replaced stock (screwed) plugs with new NGK iridiums R32 GTR clutch and re-dynoed at 174KW at the wheels (233HP for skylineusa ) . This will be the base figure for any future modifications. |
#34 | ||
Re: Re: Re: How much power do you have?
#35 | |
I'm still here
redynoed again with decent clutch good plugs and a nice mild day.
176.1kw (236hp) aprox 525Nm (387.45 ftlb) torque @ only 10.4psi (0.7bar) ![]() installing apexi AVCR shortly to try 12 - 13psi and see what gains can be made on the standard turbo and intercooler before changes are made |
#36 | |
410.7rwhp (306rwkw) at 15psi
GT3540R .82 EXH A/R on high mount manifold external gate 850cc inj poncams (all other internals stock) power fc & boost kit bosch 044 fuel pump fuel pres. reg. turbo back exh. fmic Z32 AFM
SAUWA Member 107 SAUVIC Member 279 ![]() ![]() ![]() ![]() 410.7rwhp (306rwkw) |
#37 |
![]() Join Date: Sep 2001
'91 GT-R, 531RWHP, Stock head.. |
