Go Back   Automotive Forums Car Chat > Chevrolet > Traverse
Old 07-04-2017, 09:57 PM
Blue Bowtie's Avatar
Registered Offender
Re: New Starter Will Spin - Won't Engage
Parasitic drain is commonly around 150mA on newer vehicles. 0.7V seems a little high, but that depends heavily upon the health of the battery.
The Following User Says Thank You to Blue Bowtie For This Useful Post:
ChevyMan1989 (07-04-2017)
  #32
Old 07-04-2017, 09:58 PM
ChevyMan1989 ChevyMan1989 is offline
Voltage is dropping quickly now too. Not cranking or doing anything just having a scanner hooked up and I lost 2 volts in the matter of 40 minutes. The battery is now down to 10 volts..
Old 07-04-2017, 10:01 PM
Another question for you. How hard should it be to turn the crank pulley without belt on, with a 1/2" socket wrench? I tried this a little bit ago and find it near impossible. I'm an active guy weighing 247 lb and at first it seemed to be turning ok but then it got to the point where I couldn't turn it at all?
Old 07-04-2017, 10:23 PM
Got connection to ECM again. The ECM fuse was blown. Now trying to figure out what caused it... the only thing I know is I hear some noise almost like a screeching noise comeing from inside the traverse right near where the positive cable goes from the battery under the carpet. I've checked it out though and it looks good. All wiring looks ok...
Old 07-05-2017, 08:28 AM
aleekat aleekat is online now
Pull your plugs and try it. You're fighting against compression with the plugs in.
Post back, that's what makes Forums Work.
The Following User Says Thank You to aleekat For This Useful Post:
ChevyMan1989 (07-05-2017)
  #36
Old 07-05-2017, 06:47 PM
Next update:
Somehow the fuel pump was on/running/making noise while the key was off and I was looking over the ground wires under the hood? How is this possible and is this normal?
Old 07-06-2017, 05:01 PM
Tech II Tech II is offline
You need a min of 9.6 volts while cranking or the PCM will not function....
The Following User Says Thank You to Tech II For This Useful Post:
ChevyMan1989 (07-06-2017)
  #38
Old 07-06-2017, 05:29 PM
Got it to start somehow! I just came home today and tried to start it and it fired up? It was still hard but it fired up and ran rough for 5 minutes. Now t starts up instantly and runs pretty smooth.
BUT
I ran my scanner on it and it's running rich on both bank by -10 and the fuel pressure has reached 731psi??????!!!
Is it a bad sensor or something. That fuel pressure is crazy.
