Originally posted by NiMiK
I slapped a turbo on my 96 hatch. pulled pretty good on the high end. i was boosting about 8-9 psi with a jdm 3000gt intercooler (blew the head gasket 5 months later haha) . i had a hks manifold and a kkk k26 turbocharger mounted on that. the bad part about the setup was the design of the factory intake manifold. down draft manifolds are a bummer. other than that, i had alot of fun with the turbo. i was taking on integras and what not. don't expect to beat any car with a dohc vtec motor. you could really tell the difference with the turbo going uphill. AWESOME PULL! just keep an eye on your boost level and most important, you water temp guage. expect to break something when you turbo a honda.
I wonder if the whole 3 page thread or just the first few posts was read and answered, becuase it sounds like the post is refering to a stock d-series engine, nothing is mentioned about a boosted LS. Only a "DOHC Vtec motor" is mentioned, nothing about boosting an LS. He says a DOHC Vtec motor wont beat any car (again, it had been asked about boosting a b-series, not just stock n/a b-series). 2 points here. First, read the pervious posts please, you'll see he asked about an LS and turbocharging an LS motor. The LS is a non-vtec DOHC engine. Second, I assure you, a 250 HP Boosted LS will take out plenty of cars.
As I said earlier, 12 psi on the LS engine is fine. Don't go reving the damn thing up to 8000 rpm or anything, an LS shouldn't go higher than 6800-7000. Also, if he had a SOHC D-series, 8-9 psi is pushing it a lot, that really shouldn't be boosted past 6 psi of so. Most DOHC B-series can handle 8psi or so, as I said, the LS can go up to 12 psi on stock internals. With a proper set-up, you shouldn't have water cooling problems or anything. If you are worried, drop the a/c and put in an integra radiator or a fuildyne for an integra, plus a 1.3kg/cm2 (18.5) psi high presure cap, that will help keep the engine cool. I think a lot of people run into problems with honda's and turbos by A) running too much boost, B) too much c/r for the boosted engine, C) rev the engine too high D) inadiquite fuel supply, I can go on. But in general, put out the money to have a proper turbo kit put toghter (custom kit or pre-made, have all the proper components) and and you should be fine as long as you don't overboost it. Over-reving and high reving will kill any engine quicker, n/a or turbo. Don't get worried. If you do the Turbo right, you'll be fine. And as I said in my earlier posts, the LS short block engine is the best honda engine to turbo. Great Great Block. If you really want a smoking engine, build up the internals (rods, pistons, vavles, springs, etc), do a port and polish, re-sleeve and close the deck. An engine with properly built internals can handle a lot of boost, much much more than 12psi. Properly build engines can handle 25 psi. It's all about how much $$ you want to spend in reference to how much boost you can run without messing up your engine. Since the Honda is a n/a motor from the factory, a turbo on "stock" internals will be a lot less boost (12psi max on an LS) than the EVO VIII, which runs about 19psi from the factory on "stock" internals. The difference? The EVO motor was built from the factory to handle that boost, so of course you can run it. A honda can run that boost too, but you have to build the motor up to handle it. Anyone running 9psi on a stock d-series and reving hard, like a d16, is asking for it., the engine internals weren't made for that. If you wanna do that, put in new internals and build it up.
