#31
Re: ABS Wheel Sensor Replacement 1996 Chevy 3/4 Ton 4X4
| The Following User Says Thank You to j cAT For This Useful Post: | ||
tinkering (01-06-2014)
#32
![]() The weather is going to be above zero for a couple of days; maybe I can get some things done. |
#34
Thanks, it feels more hopeful now. I'll let you know when I get the hub changed out. Maybe this thread will be of some use to someone else too.
#35
When I redid the driver's side cranking AC voltage output test I achieved 1.2 VAC. That is more than j cAT said to expect. j cAT is that OK? On the previous day I achieved only .4 VAC on the passenger side but that was with the brake caliper drag limiting top RPM. I have that caliper off now, so tomorrow I will redo the passenger side cranking AC voltage output test. I hope to achieve an output similar to the driver's side. How close does it have to be to satisfy computer parameters? I also looked through the sensor hole to inspect the reluctor gear. There was a ton of blue grease in there. Using a screwdriver, I stuffed a rag down through the hole, to make contact with the reluctor teeth. I turned the hub around by hand, intending to swab out a bunch of that grease; I did that a few times. All of the grease appeared to be very clean (no grit grime or metallic filings). There is a bit of grease still between the teeth; I can't get it perfectly wiped without pulling the hub apart. I think it is good enough. I will let you know my results tomorrow. |
#36
tinkering (01-28-2014)
#37
Should I try to shim the 1.2 VAC side out a bit to lower the VAC, or take the hub off the .6 side and see if I can clean it up to get the voltage up closer to the 1.2 VAC side? I am going to take the .6 VAC hub off and clean up the sensor mounting surface to see if the I can get the VAC to go up. If I go the shim route, where do you get shims? I didn't see any at the wreckers; I was watching for them. Can I make one out of shim stock, or a tin can or something; how thick should I go? Here is another question idea? Would it work for me to file a wee bit off of the end of the sensor, to increase the air gap; maybe .010" - .020"? I have an old sensor I could experiment with, or better yet maybe I should just get busy and make a couple of shims? Last edited by tinkering; 01-18-2014 at 11:59 AM. Reason: info changes |
#38
#39
Someone described turning the hub at approximately 1 RPS for the 'AC voltage cranking output test'; so for this last test I used 1 RPS; both side's outputs were balanced at around 0.5 VAC. If I crank like a madman I am able to reach about 1.2 VAC. I think the 0.5 VAC at 1 RPS looks right to me. I also elected at this time to change the routing of the sensor cables. The manufacturer ran it between the backing plate and the steering knuckle, where there is not enough room for the sensor coil to pass through; this made it necessary to remove the hub to change the sensor. I ran the cable along the inboard side of the steering knuckle, and then up to the 'cable guide bracket' fastened to one of the upper ball joint mounting bolts. I made sure I gave the cable the slack required when the wheel is turned to the limit. In my opinion, this is a nice improvement. After all these ABS repairs and test results on the front wheels, I will be surprised if I have to move on to the ABS computer or the ABS valve body. I should be finished the rest of the repairs on the truck tomorrow, so I will post the ABS road test results then
#40
That's it! The road test proved a success. The ABS trouble is gone, and a few improvements have been made too. I am happy too, that I don't have to go into the computer or the valve body.
Thank you j cAT and everybody for your fantastic help!!
#41
with the info on your abs repair I believe that this will be working properly for a good amount of time. good luck.. |
#42
We did a bunch of pictures of the E brake issues. You might find it a bit interesting; I am going to post them and the results at http://www.automotiveforums.com/vbul...07491&posted=1 So far, I got the E Brake working but the pedal could be higher. That is all I am going to do to it for now; it is 30 below today. |
