| Search | Car Forums | Gallery | Articles | Helper | Quality Dog Food | IgorSushko.com | Corporate |
| Latest | 0 Rplys |
Show Printable Version | Email this Page |
#31 | ||
Re: Cannot start my 94 xj...
can u gimme sum guide to rearrange my wire order on distributor? |
#32 | |
where the explode sound came from? anything bout manifold?or exhaust?
or it just bout the timing? |
#33 | |
connecting the battry cables wrong, can it cause damaged to any other part beside the fuses?like coil or ECU?
#34 | |
fred, i already change the fuses, new distributor cap, new distributor rotor, new CPS...still got the exploded sound when i rev at the high rpm...n the idle still annoying...is it the timing problem?or anything else?or i should change the new plug?
n after i cleaning the IAC, its cannot start again...n the code shown 12,33...means? Last edited by fiq; 04-27-2012 at 07:53 AM. |
#35 | |
Caution: Monkeys bite!
I believe the firing order is: 1 3 4 2, and goes clockwise around the distributor. If you have the plug wires in the wrong place it would make the explosion sound you have been hearing.
the 12 code says the battery has recently been disconnected. The 33 code I think says that there is a problem with the air conditioning. Have you changed the spark plugs? I forget. Where is the explosion sound coming from?
Ours: 2020 Jeep Wrangler 2.0, 53k 2013 Toyota FJ Cruiser, 84k Kids: 2005 Honda CRV, 228k |
#36 | ||
#37 | |
yesterday just clean the IAC...n i think i just broke my IAC...can IAC cause no start condition?i mean, no crank...after intall the IAC back, i even cannot crank my engine..
#38 | |
I think the IAC can cause starting problems, but I am not sure.
| The Following User Says Thank You to fredjacksonsan For This Useful Post: |
fiq (05-03-2012)
#39 | |
ok, thanx...i think i shud but=y a new plug tomorrow n look for a IAC at used part...
#40 | |
Definitely if you think it is broken it should be replaced.
