| Search | Car Forums | Gallery | Articles | Helper | Air Dried Dog Food | IgorSushko.com | Corporate |
| Latest | 0 Rplys |
| WIP - Motorsports Post topics for any "Work In Process" motorsports vehicles in this sub-forum. |
Show Printable Version | Email this Page |
#31 | |
Re: Ferrari F430 GT Krohn Racing
Great interior detailing! I like it very much.
#32 | ||
Thanks for your comments!!
http://www.novedadesneon.com/EPaysof...045&CatID=1496 You can find the spring in a lot of colors. If you want the spring to have a specific shape, you can insert some solder wire and bend it to that position. About the length, the springs I bought are a foot long. Hope this info helps! |
| The Following User Says Thank You to sam01contact For This Useful Post: |
rallymaster (02-18-2011)
#33 | |
That interior is looking very real.
You have a good eye for detail. Everything just looks right. Amazing stuff. And a great tip concerning the cooling hose. I have used accessories from Renaissance (look for BOAx parts) in the past. But they're rather small in size (max. 4 mm diameter) and quite expensive compared to your solution... |
#34 | |
Time for a new update!!
![]() I finished the roll cage and glued it in itīs place. I added rubber protections and attached the seatbelts to the cage: ![]() In this photo you can see that I added the missing electronic box in the rear wall of the cockpit. I wired this box and added the radio wiring (the one that goes to the driverīs helmet): ![]() And hereīs the hose that goes from the cooling box to the driverīs helmet: ![]() Thatīs it for the moment! I will begin work in the wheels and brake discs!! Thanks for watching!! |
#35 | |
Holy crap that is amazing! you must have some great reference photos
#36 | ||
Sam,
thanks for your answer and tip !! excellent !! ![]() I thought to a spring seeing it but didn't really dare to ask... Seemed too simple if not scratched !! ![]() but it's really a spring and this is a great tip ! I'll try to find such things here. And what to say about your last update which is once more a kick in the ass...!! Great details, seems real... Quote:
#37 | |
Finally, after a month of being swamped at work, I had a little time to work on the Ferrari!
Inspecting the body, I see the proportions look good for a GT car. Minimal work will be needed to represent the Krohn racing car: ![]() ![]() I'll cover the 2 NACA ducts in the front of the hood and open the square in the center to add styrene strips as air intakes: ![]() In the rear, I'll open holes for the engine cover grilles: ![]() OK, Before I do those modifications, I sand off the molded-in door panels in the interior of the body. I'll use the Challenge panels and detail them separately: ![]() And now I begin work in the body...I open the engine grilles: ![]() ![]() ![]() Next, I open holes for the rear ventilation grille. In this area, I open little holes for the engine cover fasteners: ![]() ![]() While I work in the body, I prepare the little details for paint (lights, emblems, grilles, etc.): ![]() ![]() ![]() I open holes for the antennas and prepare their bases using hypodermic needles. I use a sharpening stone to level every cut I do on the needles: ![]() ![]() ![]() In the sides, I only need to open holes to mount the side mirrors. It's also necessary to fill the key holes in the doors. I use cyanoacrylate to fill the holes: ![]() ![]() In the Studio 27 kit you will find white metal pieces to cover the NACA ducts if you want to. I use this pieces and cover them with cyanoacrylate to fill the holes: ![]() The nose air intakes of the GT car must be more "square" than those in the Challenge version. You must have a lot of patience and care in this step, because the Studio 27 body has a lot of bubbles and irregularities in this area: ![]() That's it for now! I hope to show you the painting process in my next post. Thanks for watching!! |
#38 | |
Thanks to a couple days off from work, I had some time to advance in this project:
Still in time, I realized I needed to make holes in the sides and front for some bolts. ![]() ![]() I also needed to add a styrene strip to complete the "frame" of the air inlets in the front bumper: ![]() This image shows the interior door panels detailed and covered with carbon fiber: ![]() I realized the tyres were a little small for the rims, so I placed them in a tube a month ago, so they could stretch a little. Before I removed them from the tube, I applied warm air with a hair dryer to prevent them to shrink to their original size: ![]() After placing the tyres in the rims, I applied the decals using some microsol. To make the decal film disappear, I placed a coin over the rims and sprayed some flat lacquer to the tyres. The coins prevented the lacquer to land on the rims, so they stayed shinny ![]() ![]() Hereīs a photo of the finished wheels. I used 2 sets of Hobby Designs rims (the rear rims should be "flatter" than the front ones). I sanded off the center nut and replaced them with Scale Production nuts: ![]() And finally, I began the paint process! First, I applied a "guide coat" with gray primer. That way, is better to see and correct any imperfections (in this photos you can see the hood air inlets I did with styrene stripes): ![]() After correcting all the imperfections in the body, I applied 2 coats of white primer, as a base to the fluorescent green: ![]() ![]() After wet sanding the white primer with a 8000 pad, I applied the green colour. This was a mix of fluorescent yellow and fluorescent green from ZERO PAINTS. The paint is very easy to apply and it dries with a matt finish, so it is very easy to sand off any dust particle or imperfection: ![]() ![]() ![]() After 24 hours in the dehydrator, I applied ZERO PAINTS clearcoat. This stuff is simply excellent! The coverage is great and if you apply a final coat with a little more thinner, you end up with a great shine!! ![]() ![]() ![]() Well, thatīs it for the moment. Next, I will paint the inside of the body and put the decals!! Thanks for watching! |
#39 | |
Wow, love the Colour!!! Excellant work on the details too!!
It's Not wheather you Win or Lose, its how you look while you play the Game |
#40 | |
very cool! i was hoping you would resume work on this build!
#41 | |
Fun update to read through. Good job on the body prep
#42 | |
eye-catching color !!
it's almost a pain there will be a livery to cover it !! A plain color body with only the racing attributions over will be the best livery possible IMO once all painting details done and PE details added. |
#43 | |
Mugrosa's Alley
this is an awesome build, lots of good tips in this wip thanks and keep up the good work
I'm a Marine, I got this! |
#44 | |
Awesome skills my friend !
Mart Bee |
#45 | ||
Thanks for the kind words! I am having lots of fun with this one!
In this case, I actually like the contrast between the blue stripes and the green colour. |
