#406
Re: Passlock System
Tell me first what it's doing now when it won't start. What is the security light doing? You may want to try the relearn technique before going any further.
I think we could try to use 2 relays with the proper resistance to fool the system. Again, I don't know for sure it this will work. That's why I want to rule out everything else. You've changed a few things so maybe a relearn would take care of everything????
Silverado Ext. Cab 4x4 z71 Pioneer 4900mp Orion P6.2 Componet sets front Orion C63 Coax rear DirectedVideo 9" all in one DVD with surround 2007 SATURN OUTLOOK AWD XR with full entertainment package |
#407
Re: Passlock System
Re: Passlock System
Well, to do the relearn the light should blink after you crank it. Then shut it off and imediately crank it over. If it doesn't start leave the ignition on for 11 minutes. After then try to start it, if the same happens, leave the ignition on for another 11 minutes and try it again. It's not uncommon to take 45 minutes or longer to do this.
#409
Re: Passlock System
Re: Passlock System
Hmm, well either somehthings up with the wiring to or from the cluster, the bcm, or the bcm itself is toast. You could try to do a bypass on this system but I've never tried it. I have an idea how to do it but I've never tested it.
#411
Re: Passlock System
I understand you've never tried it but at this point i'm willing to try anything, so shoot it at me. |
#412
Re: Passlock System
I am not sure if it is my Passlok system or what. I have 2004 Malibu Classic. Car always starts after it has set for an extended time. It has recently gotten to where if I have been driving it and get out to go into the store for a short time, when I come back it will turn over but not start. Theft light is off. If I try to start two or three times it will typically start. I have been driving and noticed that speedometer and tach dropped to zero for about 2 seconds and theft light flashed and then everything went back to normal and engine continued to keep running. Two days ago when I went in the store and came out the vehicle would not start. Left the ignition on to try the 11 minute trick. After about two minutes doors locked again, buzzer went off, theft light came on and went off. Tried vehicle and it started right up. Similar issues to what is posted but also different. Is this an ignition switch? Would appreciate your thoughts
#413
Re: Passlock System
Sounds like your BCM is going bad or there's a short in the harness for sure. You'll have to take it to a technician and have them hook it up to their scanner. I'm sure it'll say there's a loss of data communication.
#414
Re: Passlock System
You could do this as well just using relays and resistors but if you haven't really got into one of these systems before I think it'd be a little too daunting.
#415
Re: Passlock System
1) I followed the resistor procedure and the car now runs, but the security light is always on 2) I disconnected the battery overnight. When I reconnected the battery, the security light is still on all the time. 3) I disconnected the BCM. No change Ever since the initial procedure, I have had no trouble with the car not starting. The problem is completely gone. However, I am worried that some day the computer is going to get reset and the car will no longer start and strand me somewhere. Any thoughts about what to do next? Thanks again. |
#416
Re: Passlock System
Hi There Folks
First I probably give you the info on what happened to me. I own a 2003 3.4l impala. I bought it in June and it had 34 500 km. It now has approx 47,000 km. About a month ago a light came on indicating I needed an oil change. I ignored it and about a week later the check engine light came on. I usually only drive in the city, fairly short runs. About 3 weeks ago I drove out of town approx 200km. Stopped in to get some grub, came out, car wouldn't start. Not a gig. Tried a boost, nothing. With the key in the on position, the security light came on along with the battery light and the pic of a car with an opened ended wrench on the side of it. The door transponder wouldn't work or the trunk opener. The power windows buttons worked, the wipers worked but the radio didn't work and the dome lights didn't work. Waited 1/2 an hour, turned the key, perfect. Drove back to town and stopped at a store, come out turned the key, not a gig. Waited 20 mins and it started. Drove the car around in town for 3 weeks not a hitch. Went out of town again (200km) same thing happened. No start. Waited 1/2 an hour and she started. I thought that it might have something to do with the long run. Now the problem is occurring on a daily basis. Broke down the other day, called the dealership and they suggested it was probably the battery. They also told me that they never came across this problem before. What a crock. Bought a battery for $116.00, put it in, car started, eureka, problem solved right, Wrong! Later that afternoon of about 3 stops and starts on the 4th, no start. Waited 1/2 an hour, car started. The next day I decided to go do my business so I took the extra set of keys and would leave the car running, lock the doors with the remote. I would come out press the unlock door button, best kind. Done this about 5 times worked ok. The 6th time it didn't work. Had to use the key to open the door. My buddy is a mechanic and he put it on the scan tool. Apparently it showed a "u" code which is a communication code. Apparently there are 4 computers in the car. The BCM, ABS computer, Air Bag computer and the anti theft. Apparently all these computers are supposed to be yakking to each other. For some reason the anti theft is not talking to the air bag, which in turn is causing my car not to start. What's up with that? If someone needs the exact code numbers let me know. GM has a serious issue with their Pass Lock system. Now I have investigated a lot of weird stuff but this one is all GM (To blame). To make a very long "root cause investigation" short... 1) They (GM) have used connectors in the ignition Pass Lock system which do not mate up properly. 2) They (GM) did not use gold plated connector pins for this specific application. 3) They (GM) did not understand compensating software for the Body Computer. The main issue is that, over time, the Pass Lock connector pins oxidize. This oxidation changes the critical analog Pass Lock signal to the Body Computer. So the Security light comes on whenever and the car does not start whenever. You can buy a Pass Lock "bypass kit" online and disable the system... easy and cheap. I ended up hand soldering the three wires (Black, White and yellow) directly to the Pass Lock sensor on the ignition switch. Not so easy but it does not disable the security system... My Impala is finally fixed and it cost me nothing... So now everyone knows the truth about your expensive GM problem! Maybe a Consumer Advocacy group would like to contact me as a "key wittiness" in some litigation? I have a very advanced background in Electronics, Automotive Engine Management Systems and a Degree in Computer Science. Presently I am working as an Embedded Software Engineer. Dr Zach I have to go to the Dealer on Monday and their going to do a scan $95.00 an hour and if the ignition is gone and they have to replace it, it takes another 1/2 an hour to program it and I don't know the cost of the switch. Should I try to bypass the Passlock 2 system by cutting the yellow wire and installing a toggle switch. Thanks Bill |
#417
Re: Passlock System
No. The toggle switch will not cure your problem. You should do the resistor trick like what I've stated before.
#418
Re: Passlock System
dear isetheby aka dr zack,
this is a nagging problemlok at the size of the thread. is there any chance you able to post the precedure(photos, schematic, location of said components,etc.? regards and be well, fish96 |
#419
Re: Passlock System
Interesting. Normally when you do the resistor trick it'll normally either start everytime or won't at all. When you turn the ignition on but not in the run position does the security light flash???? You may need to try the PK2 relearn procedure.
#420
Re: Passlock System
I have a 2002 Alero,In my manual they refer to this system as a disabler, It doesn't only work for anti theft purposes but disables the ignition when service lights are ignored....Does this cutting the yellow wire and adding a toggle switch work for my car ?? I am sooooo tired of this damn thing going off for no reason...I am a health care worker who drives from home to home and having to wait an extra ten minutes between clients cuts into my paycheque.
Anyone with any help or answers would be sooo appreciated. |
