| Latest | 0 Rplys |
Show Printable Version | Email this Page |
#361 | |
Does anyone know how to program
does anyone know how to reprogram a keyless entry for a 1991 Caprice Classic, the keyless entry was a factory add-on.
#362 | |
I have a 1994 Chrysler T&C AWD I Need To Program
the remote. I would like to know How?? |
#363 | |
Re: Keyless Entry Questions Ask in here.
So does reprogramming a remote for a 2003 Malibu require a scan tool?
#364 | |
I want to add keyless to my Blazer.
Can I use another chevy keyless receiver module if the connector is the same? The 98 to 2000 Blazers all us the same module. Will other chevy ones from these years work??? |
#365 | |
Reprogramming a Ford keyfob for an Olds Silhouette ?
I have a '97 Ford Ranger keyfob (TRW-3165189, FCC ID gq43vt4t, DOC 1470 k763, transmitter 2) that I'd like to reprogram to use on my '99 Olds Silhouette. Can this be done--crossing brands--or do I need to buy a blank off of ebay? The Olds keyfob says: (GM 10245953, Canada 218 101 487, FCC ab00204t). Thank you, in advance.... |
#366 | ||
![]() Join Date: Sep 2004
Re: Re: Keyless Entry Questions Ask in here.
#367 | ||
#368 | ||
#369 | ||
Turn the ignition switch to the ON position. Turn the ignition switch to the OFF position. Turn the ignition switch to the ON position. Turn the ignition switch to the OFF position. Release the power unlock button on the door panel. The remote control door lock receiver will respond in the following manner in order to indicate that the receiver is in the programming mode: Locking the doors Unlocking the doors Important All extra transmitters must be programmed at this time. When a new transmitter is programmed, the old transmitters will be deactivated. Hold down the lock and unlock buttons on the transmitter until the remote control door lock receiver will respond in the following manner: Locking the doors. Unlocking the doors. Repeat step 7 for each additional transmitter. Turn the ignition switch to the ON position in order to exit the transmitter programming mode. In order to reprogram the remote control door lock transmitter with a scan tool, refer to Scan Tool instructions. |
#370 | |
Does any one know how to program the remotes for a 99 olds alero 4 door?
#371 | |
how do program the remote for the keyless entry on a 2000 monte carlo
#372 | |
Does anyone have the instructions how to program a 2004 venture with one sliding door and no alarm system? ANy help is greatly appreciated!
#373 | |
2001 Town & Country LXi keyless Remote
Hiya. I purchased a remote for my 2001 Town & Country to replace one that I'd lost. However, I've misplaced the manual, and tried the advice listed in a different forum for programming a keyless remote for a 2000 T&C, but no bongs indicating programming, nor any success in the programming itself. Could someone tell me how to program the new remote? And without losing the data on the old, working remote? Thank you for your help.
JB |
#374 | ||
![]() Join Date: Jul 2003
This did not work for my '99 Tahoe. When I released the power unlock button the receiver did not respond by locking & unlocking the doors. It can't be the keyfob because I haven't gotten there yet.
When I released the unlock button it sounded like it usually does when it releases the locks. I exepceted it to lock & unlock the doors. Any ideas? Quote:
#375 | |
2000 grand prix GTP keyless problem
Ok I feel like I have posted this thing all over the place but at last I think I finally found the right spot. Here is my question:
My 2000 Grand Prix GTP's keyless entry seems to not be working properly. I replaced the battery on the remote and it still did not work. I changed the #29 fuse and then the keyless entry started working again for about 2 days and then it stopped working again. I inspected the fuse and it did not appear to be blown but I replace it again and then it started working again for about a day and now it has stopped working. Anyone have any thoughts as to what the problem could be? Thanks, Craig |
