#316
Re: Passlock System
Thanks to all early posters on putting a switch inline on the yellow passlock cylinder wire. After suffereing stranding for the last time, I acted on my 2002 Malibu. My biggest problem was getting the stupid passlock to work one last time so I could flip the switch to off that I installed while waiting the multiple 10 minutes between tries. I now have the comforting solid-on security warning light as advertised, and am hapilly driving with confidence in starting first try.
#317
Re: Passlock System
Great! Just pray to the Lord above that your battery never dies or needs replacement because when it does you will for sure need to spend $600 at the dealer. Now if you get the nuts to dive into it to perminately bypass it get some resistors, a multimeter, and a solder iron and go to it!
Silverado Ext. Cab 4x4 z71 Pioneer 4900mp Orion P6.2 Componet sets front Orion C63 Coax rear DirectedVideo 9" all in one DVD with surround 2007 SATURN OUTLOOK AWD XR with full entertainment package |
#318
Re: Passlock System
I'm so glad I found this website. My son's 1999 Pontiac Grand Am also has the security light come on and not start from time to time. We are going to take my son's car to a mechanic friend of ours on Thursday. Our friend said that as long as I can provide the instructions he would be willing to work on the car. I've printed the instructions regarding the PK2 system and resistors. Was there are certain area where the resistor(s) should be placed and if there is, is there a picture or diagram of it? I would like to provide all the correct information to our friend.
Thank you for your help! |
#319
Re: Passlock System
No. You can put the resistor anywhere between the ignition switch and the BCM
#320
Re: Passlock System
Thanks again ponchonutty... -Scott |
#321
Re: Passlock System
We left the car off last night with our mechanic friend. He says the instructions are very good. He's going to check everything out to make sure it's not the BCM before proceeding any further.
Thank you for your help ponchonutty, it's much appreciated.
#322
Re: Passlock System
Could we have avoided the tow by disconnecting and reconnecting the battery before giving up? Before replacing the BCM for other issues (no door locks, no radio, no interior lights, no chimes) the technician got the car running by "bypassing the security system." However, there were still issues that ended up being resolved by replacing the BCM. I never could find out what "trick" he used to "bypass the security system." The battery thing would be good to know ... if it works even temporarily for passlock issues.
2001 Alero (V6 3.4L VIN E) 1999 Malibu (V6 3.1L VIN M) Last edited by gen6eric; 09-30-2008 at 11:51 AM. |
#323
Re: Passlock System
gen, if you have BCM issues, there's no real way to bypass the system. He probably just reset it and at that time, everything work at that moment so it could start. When you have a BCM problem there's not much you can do even my method of bypassing the PK2 system
#324
Re: Passlock System
It would be nice to think that the passlock issue was solely because of the BCM that was corroded. If so, we wouldn't have to worry about future passlock problems. But, that would be too good to be true, so I'm not holding my breath and will see if my husband will do the "resistor" treatment to avoid future issues.
2001 Alero (V6 3.4L VIN E) 1999 Malibu (V6 3.1L VIN M) |
#325
Our friend talked to a mechanic he's known for years. The mechanic talked him out of using the resistors because he said they would eventually burn out and then we would never be able to start the car again. A new ignition was put in. The real kicker to me is my son was told that this ignition may act up too. If it does, to put the key to the "on" position for 10 minutes and it will start up. He had already been doing this with the old ignition.
My question...how long do the resistors last and do they burn out periodically? |
#326
Re: Passlock System
In may 2002 I installed a 2.2 K ohm resistor to by pass my auto head lights, still works. I would say in the ignition system they would only last about 50 to 100 years, your mechanic was untruthful.
#327
Re: Passlock System
#328
Re: Passlock System
BTW, I've only had to replace the resistors one time out of about 40 cars I've done this to.
#329
Re: Passlock System
why wouldnt you be able to reattatch the wire if you had cut it, instead of going to the dealer and having them give you a prostate exam?
I ask B/c i am looking into purchasing an 1998 isuzu hombre with symptoms that sound just like this. also would any of you know whether this vehicle has passlock 1 or 2. thanks for the good read alot of great info in here |
#330
Re: Passlock System
The hombre is just like the S-10 pickup so it'd be the PK2
