Old 03-23-2010, 09:49 AM
00GTP4ME's Avatar
00GTP4ME 00GTP4ME is offline
Re: Aftermarket Security System?
Originally Posted by tblake View Post
Yikes, I could just buy a new one for that!
Psch! Or two or three!
2000 Pontiac Grand Prix GTP 3.8L SII V6 S/C
2000 Jeep Grand Cherokee Limited 4.7L V8
1996 Chevrolet Camaro Z28 5.7L V8
1993 Chevrolet Suburban K1500 5.7L V8
1991 Ford Probe LX 3.0 V6
1986 Ford Tempo GL 2.3L 4 cyl.
Old 03-23-2010, 10:35 AM
00GTP4ME's Avatar
Well I just heard back from the insurance company and they're not going to touch the fog-light, DIC, or climate control lights because the dealership said that they didn't think the issue was related to my dash being torn apart. On one hand I can see their point because I have no clue how you could prove something like that, but on the other, I just find it a little beyond a coincidence that all of those things would just go out at once simply because of the age of the car. Oh well.
Regardless, I'm definitely going to attempt to repair the fog-light switch and DIC because those look simple enough. As for the climate control lights, can anyone give me any details as to how to do that? I know it was mentioned that those bulbs had to be soldered. Can anyone tell me what bulbs I'd need, can LED's be used, and any other helpful hints/suggestions?
Thank you so much.
Old 03-23-2010, 11:49 AM
doctorhrdware doctorhrdware is offline
I had a friend that was having memory issues. When I worked there it was free. He called bad buy and told him it would be $70 each stick of memory. So he just bought 2 sticks for $100. So he saved $40. The memory had free shipping.
Old 03-23-2010, 11:56 AM
Yes you can LED's for the bulbs for the climate control head. The only thing is that the LED has polarity. So you need to know the polarity of the bulbs that you are replacing with LEDS. Also you need a 1k ohm dropping resistor to limit current going to the led. Off of the top of my head, I can't remember what was the positive buss on the climate control head. If you can't find the solder wick I have some that I could send out to you.
Old 03-23-2010, 12:10 PM
00GTP4ME's Avatar
How do you make the current go through the resistor before it gets to the LED? I'm picturing a circuit board with two little holes for the positive/negative LED/bulb wires. Do you just stick the bulb AND the resistor in the same two holes (bulb negative and resistor negative in one hole and bulb positive and resisitor positive in the other)? That would be parallel wiring, right? Sorry, I'm not very electrical savvy.
That's very kind of you! My father-in-law used to be a VCR repair man so I know he has some. Thank you though!
Old 03-23-2010, 12:12 PM
The resistor is connected to one lead of the LED. I will see if I can find a diagram and post it for you.
Old 03-23-2010, 12:25 PM
00GTP4ME's Avatar
Ok. I tried to look really carefully at Tim's post here:
http://www.automotiveforums.com/vbul...d.php?t=925884
And I couldn't really tell how he had them in there. So you connect one side of the resistor to one side of the LED and then the opposite sides of each are what is connected to the circuit?
Sorry for the tangents everyone. I always do that. For now on, I'll just name my threads, Another Matt Thread.
Old 03-23-2010, 12:28 PM
The LED can be damaged by relatively low reverse voltages. The diagram below shows how the LED package is marked for polarity. Connect the resistor to postive lead and solder the resistor lead to the plus lead of the LED. The Minus lead is the ground and the plus lead goes to the + lead of the climate control head. Hope that this clears up on how to use the LEDs.
Old 03-23-2010, 12:34 PM
rkvons's Avatar
rkvons rkvons is offline
It would be a series connection. The current goes through one of the two components and then through the other. So they are daisy chained. It does not matter which order, but the polarity is important. Connect the 1K resistor to the positive terminal of your battery, then try connecting the LED from the resistor to ground. If it does not light, reverse the LED. When it lights, solder the resistor and LED together. Now you just need to find the positive source in the circuit where you want the LED to go. You connect the 1K resistor to it and the other end of the LED to ground.
Old 03-23-2010, 12:42 PM
00GTP4ME's Avatar
Ah, ok. To cement that I understand, I drew this up. Is this correct?
Old 03-23-2010, 12:44 PM
But the way the climate control head is laid out, you have to use 1k resistor on all of the installed LEDS. That is how I re-lamped the climate control head in my 97 GP.
Old 03-23-2010, 12:46 PM
00GTP4ME's Avatar
Oh really? You put in all LED's on your climate control?
That is perfect!!!!
Old 03-23-2010, 12:50 PM
00GTP4ME's Avatar
That is perfect!!!!
Woo Hoo! Thank you so much for your help, I really appreciate it! Sorry I'm slow.
When you did your climate control, you totally should have taken pics and posted a write-up. That would've been awesome. Do you recall how many bulbs were required? What color did you use? If I want it to look factory, should I just use white LEDs?
Old 03-23-2010, 01:01 PM
No problem. I fixed the climate control head before I was a member here. I found this site because I had a hub speed sensor problem and a coolant level sensor. Otherwise I would have taken pictures.
