Go Back   Automotive Forums Car Chat > Panoz > GTRA / GTWS / GTS
Old 03-27-2010, 05:44 PM
panozracing's Avatar
panozracing panozracing is offline
Re: Hey Brian...
NICE NICE NICE!!!!
Did you have to break out the jig saw at the track? How much did your times drop if any?
Glad you like them! I guess they still have some life in them :-)
Brian G.
2000 Panoz GTS #420
NASA ST1
427ci Stroker
Old 03-28-2010, 04:25 PM
Squerly's Avatar
Squerly Squerly is offline
Re: Hey Brian...
Originally Posted by panozracing View Post
NICE NICE NICE!!!!
Here’s my “beyond the smile” report!
These bad boys really stick, once they get warmed up that is. Which means the first couple of laps (especially in the early morning) can prove to be quite interesting… I would compare it to riding around on ice. Well maybe not that bad but you have to be careful.
I started out cold with 28 lbs which turned to 33lbs rather quickly. Dropped that back down to 31lbs which seems to work well. As for being faster, there is just no doubt about that. In my case I found myself going into corners much faster than usual. Exit was also quite a bit faster given that the tires are so forgiving. When the ass end starts to get loose it is very predictable, and therefore quite easy to control with the pedal. At least it was for me.
Braking was very much improved, especially coming to the end of the back straight at 10a. As I got more comfortable I found myself halfway between the 200’ and 100’ marker before I got on the binders. And that’s pretty good for me as I’m always braking way too early in this area.
My overall time was much better, but I can’t tell you how much better as I wasn’t timing my runs. But there is just no doubt that the faster entry and deeper braking made one hell of a difference.
I know some of us are keeping our cars completely "panoz stock" for racing purposes. But if you are not one of those, this is an easy mod with spectacular results. In fact, it’s harder to find someone to mount the tires than it is to modify the car.
Squerly
Old 03-28-2010, 07:17 PM
Squerly's Avatar
Re: Hey Brian...
No, the 2" that you recommended was perfect all the way around. Good thing too cuz I forgot to bring the saw!
Squerly
Old 03-28-2010, 07:26 PM
Dawgfan Dawgfan is offline
Re: Hey Brian...
Squerly/Jim. Sounds like everything went well for you this weekend. I was coming out but got real busy and Saturday was Vee's birthday. Do you have your old wheels and would you consider getting rid off them?
Old 03-28-2010, 07:31 PM
Squerly's Avatar
Re: Hey Brian...
Sure Mike, I have 10 -18" BBS rims and I would consider selling 6 of them. I'll keep a set handy until I can get some backup CCW rims for my new Meats! What's the going price for a set of used BBS rims?
Squerly
Old 03-29-2010, 02:10 PM
Cobra4B's Avatar
Cobra4B Cobra4B is offline
Re: Hey Brian...
Wow that looks killer! We're stickign w/ the 17" BBS and 275/40/17s right now for cost and because the car is setup around NASA TTS/ST2 rules.
I used to have classics on my yellow Z06
Brian B.
Panoz GTRA - LS1 swap in progress
#4 Z06 - NASA ST3/TT3
Old 03-29-2010, 02:14 PM
Cobra4B's Avatar
Re: Hey Brian...
Just noticed that you don't seem to have any hood latches other than the original 4 and the 2 screws at the rear middle... any issues w/ hood flutter?
We converted the 4 hood supports to hoodpins to prevent it from flopping around at speed @ VIR.
Brian B.
Old 03-29-2010, 02:28 PM
Squerly's Avatar
Re: Hey Brian...
heh, heh... I have to force myself to ignore the hood lifting up in front of me... Been considering putting in a periscope.
Squerly
Old 03-29-2010, 05:44 PM
Re: Hey Brian...
Jim, I don't know. They are your wheels. I hate to price other peoples thing.
Old 03-29-2010, 06:55 PM
Squerly's Avatar
Re: Hey Brian...
Well, I'm looking for a motor home. I could trade you straight across if you've got one you want to get rid of...
Squerly
Old 04-13-2010, 07:36 PM
Squerly's Avatar
Re: Hey Brian...
24 posts and 458 views, but not one of you speed junkies has asked what's under the sheet!
Squerly
Old 04-13-2010, 07:39 PM
Panoz26's Avatar
Panoz26 Panoz26 is offline
Re: Hey Brian...
Hey Squerly -- whats under the sheet over in the corner
Devin - (aka Panoz26)
Formally WC Car # 26, Red
Now = WC-GT2 # 211, Black
Old 04-13-2010, 08:32 PM
Re: Hey Brian...
u had to ask....he was kind enough to cover it in front of me :-)
Brian G.
2000 Panoz GTS #420
NASA ST1
427ci Stroker
Old 04-13-2010, 08:44 PM
Squerly's Avatar
Re: Hey Brian...
That would be Quick Silver...
  • Quick Silver uses T25 turbochargers tuned with a hundred octane program to produce 710 HP and 755 Lbs Torque at 1.6 bar of boost.
  • Stage 4GT turbo conversion from Evolution Motor Sport.
  • BMC high flow air filters
  • GT2 Intercoolers
  • Billet diverter valves
  • Bilstein PSS9 coil over suspension
  • HRE 841R wheels. (265/30/19 Front and 315/25/19 Rear)
  • Brembo 8-piston 15" front brakes and 4-piston 14" rear brakes
  • 993 style hood, made from a stock aluminum hood
  • Gemballa Evo body kit, Wide body, added 1.5" per side to the front and 2" per side in the rear.
  • GT3 Seats and GT3 Roll Bar
  • Car was featured in the June 2004 issue of European Car.
File Type: jpg PEACHSTATE ROAD ATLANTA June 10-11, 2006 DL - 11 343l.jpg (94.4 KB, 40 views)
Squerly
Old 04-13-2010, 09:33 PM
Panoz26's Avatar
Re: Hey Brian...
dayum will u take me for a drive?
