Old 03-17-2010, 11:21 AM
rx7king's Avatar
rx7king rx7king is offline
Re: Ferrari 250 GTO Le Mans 1962 N.A.R.T. (chassis #3387)
wow this is a great build. great work correcting the body
Old 03-23-2010, 05:50 PM
godfather23's Avatar
godfather23 godfather23 is offline
Update.
Iīm still working on the body corrections. The air ducts behind the doors have been modified.
The inlays for the leather straps on the front bonnet and the body have been filled. Using the PE-straps makes the unnecessary.
The body as it waits for further primer and sanding.
The front cooler with a PE-part added.
The metal exhaust tips from Hobby Design.
I started work on the chassis. All Parts have been primered using a flat primer and then flat black and various shades of silver have been added to the parts. The wheels have been primered using the Tamiya Metal Primer and then I added two layers of Mica Silver (TS-76).
The brake discs were enhanced using the PE-parts fromt he Hobby Design Set. I refrained using parts of the PE sets because I figured the wheels would fit better. They then have been painted acrylic iron and some rust was dry-painted.
Thatīs all for now and I think the pictures show that I will go curbside.
Cheers
Robert
Recently finished Projects:
Porsche 911 Carrera RS 3.0
Current Projects:
Old 03-23-2010, 07:21 PM
jaykay640 jaykay640 is offline
Nice progress!
The wheels look a bit bright but i guess that's just too much contrast in the pictures :-)
Old 03-24-2010, 02:24 AM
True. I was taking the pictures last morning, when the sun came out. If they seem to me too bright on final assembly I will tone them down.
Robert
Current Projects:
Old 03-24-2010, 02:40 AM
countach79's Avatar
countach79 countach79 is offline
nice so far!!
I just received my hobby design full kit today!!
Old 03-30-2010, 07:56 AM
Update.
The body received the white stripe. I chose not to decal this stripe since the white part also goes around the front. Therefore from my past experiences it is better to mask that part and paint it.
I also started with the interior. The instruments panel is done. I enhanced it using the parts from the Hobby Design Detail kit. The steering wheel will receive a glossy finish later on in this project.
Cheers and thanks for looking. Comments are welcome - as usual.
Robert
Current Projects:
Old 03-30-2010, 10:23 AM
360spider's Avatar
I wonder why did you mask the body to spray the stripe. I'd just spray the area white, then mask it of and spray the blue. That way you don't have to mask it twice, and no worrying about matching the mask.
ItalianHorses.net
Old 03-30-2010, 10:51 AM
I thought about that as well. From my experience by doing it this way I escape two problems:
- too much (thick) paint on the body
- paint works the best when sprayed onto primer
These are the main reasons why I masked the stripe. Besides that it was the first try using maskol by Humbrol. Using it the first on doing a white stripe on white primer looked less risky in means of messing something up. Once I have more confidence in this product I might work around an extra round of masking.
Robert
P.S.: The last reason for this masking is me being sometimes a little overcomplicated and super-careful.
Current Projects:
Old 03-30-2010, 12:09 PM
gtziaf's Avatar
gtziaf gtziaf is offline
Very good job...
What colour use for steering wheel (the wooden part)?
Good luck until the end...
Visit our Greek Modelling Forum :
http://scalewheels-gr.com/
Old 03-30-2010, 02:11 PM
MidMazar's Avatar
MidMazar MidMazar is offline
Originally Posted by klutz_100 View Post
For simple shapes you don't really need the vacuum, you can pull the heat acetate over the original part (I did this for headlight covers on the Revell 612)
HTH
Hey klutz, won't the acetate stick to the original part?
In Progress
Old 03-30-2010, 02:54 PM
Veyron's Avatar
Veyron Veyron is offline
No. I also did it to make clear tail lenses for my custom 350 Z....but I used .015 Butyrate, not acetate, which holds it's shape better.
Old 03-30-2010, 08:34 PM
ddtham's Avatar
ddtham ddtham is offline
Nice fixes! I need to get myself one of these now
Old 04-02-2010, 07:13 AM
Thank you for the question. I used the "new" Revell aqua color no. 382 over a base of Tamiya white Primer.
Current Projects:
Old 04-02-2010, 07:43 AM
The paint arrived. I had the azzurro california metallic blue (ferrari-color-code 524 - offerded for the 2009 Ferrari California) mixed by a german company I found on the internet. I just couldnīt wait to lay it onto the model.
First I wanted to see how the color would look like. Therefore I painted a plastic strip and added a layer of TS-13 afterwards.
That looked good to me. What the pictures doesnīt show is that the blue is changing in its depth and darkness depending on how much bright light you view it in.
The color looks pretty much right to me. The blue is darker that what I used before. The pictures show a little too greyish shade of the color. Nevertheless it is much bluer than it appears on the taken fotographs. It comes very close to what the car was actually painted with in 1962:
This morning I masked the white areas and then added 3 mist coats of the color. It worked very well. The custom mixed paint was great to work with.
And then ... I removed the masking. Almost no bleed through and almost no sharp edges where the blue meets the white.
I let the paint gas out over night and will add two or three layers of clear before starting the laborious task of sanding with 2000 grid paper and rubbing the surface with Tamiya finishing compounds.
Cheers
Robert
Current Projects:
Old 04-02-2010, 09:33 AM
Porsnatic Porsnatic is offline
Unbelievabable!....this is the way a Ferrari should be painted!...by the way, could you tell the address for the German company who mixed your paint?
