| Engineering/ Technical Ask technical questions about cars. Do you know how a car engine works? |
#16
Re: No Ignition
I don't know what that means but yes it does.
#17
Re: No Ignition
I was also talking to another local mechanic and he said to check for chaffing of the wires leading to to PCM, i could not find any chaffing. I was also wondering if there could possible be a fuse im missing from in between the ignition switch run position to the main fuse box under the hood? Nothing seems to be making sense ive checked everywhere i can think of. |
#18
Re: No Ignition
The PK3 key is PassKey 3, there is a small glass capsule in the rubber head with a transponder in it. If the transponder is bad or not programmed in the PK3 system will shut the systems down.
1997 Chevrolet Venture SFI 3.4l Auto 249k 2006 Chevrolet Malibu Maxx SFI 3.5l Auto 81k http://www.s10forum.com/forum/attach...nsor-chart.gif |
#19
Re: No Ignition
On the GMs will the Theft or Security indicator flash if there is an issue with the Passkey system, or will there be no noticeable indication without getting a professional scan tool and scanning the system? On Fords the indicator will flash rapidly when trying to start the vehicle if the PATS system doesn't recognize the key, but I'm not sure about GMs.
-Rod |
#20
Re: No Ignition
Refering back to Selectrons post, diagram#1, following the igniton key down is P100 a grommet that goes through the firewall?
#21
Re: No Ignition
I've never seen that symbol before, but apparently it is indeed something which GM use to indicate a grommet (if you select the 'grommet' answer for question 18 on this ASE test page, it confirms that). Are you any closer to solving this one?
#22
Re: No Ignition
I had to set this problem aside for a bit and move on to other projects. I will probably get back at it this week. I have been talking to some other mechanics and one told me to put 12 volts directly to the ICM and see if it starts. It didn't start but I got ignition. I haven't worked on it since.
