Go Back   Automotive Forums Car Chat > GMC > Sonoma | S-15
Old 12-05-2011, 07:49 AM
maxwedge maxwedge is offline
A990 racer
Re: 1992 GMC Sonoma Stalls during acceleration
Wow thats a lot of parts did these all fail or is this fix by trial? When it dies does it start right back up?
Old 12-05-2011, 08:54 AM
bmiller184 bmiller184 is offline
Its been fix by trial but the truck probably needed the new parts. The truck was neglected and probably was never maintained correctly. It struggles but it will start right back up but again only with accelerator push down slightly. I was told to try and replace the thermostat and temperature sensor.
Old 12-05-2011, 11:40 AM
A990 racer
Get a scanner on it and look at the temp sensor input first. See any of the injectors are leaking down also.
Old 12-05-2011, 01:02 PM
So I replaced the coolant temperature sensor and the thermostat and it seems to be doing better but not perfect. It only has one injector and idk how to check it. The truck fires right up and idles fine until you rev it up and when it idles down it idles rough or dies
Old 12-05-2011, 07:12 PM
A990 racer
Disconnect the egr see what happens.
Old 12-05-2011, 08:52 PM
I found the egr and it was already unhooked but I don't see any vacuum line hanging that should connect to it.
Old 12-06-2011, 07:27 AM
A990 racer
Ok, but it could be stuck open or carboned up, take it off an and clean it up, if partially open it can cause hesitation and stalling.
Old 12-08-2011, 03:46 PM
It looked like it had never been replaced so I went ahead and replaced the egr valve and the sensor the vacuum hose runs to and its getting better but still spits and sputters while idling and if you rev it up it spit and sputter then dies. Unsure what to do I believe I have replaced everything possible.
Old 12-08-2011, 07:48 PM
A990 racer
How is the fuel pressure? Does it have a mass air flow sensor, if so disconnect see if runs any better.
Old 12-08-2011, 07:53 PM
Its got a map sensor instead of mass air flow sensor but fuel system is all new besides fuel lines and fuel injector
Old 12-23-2011, 06:20 AM
xxmtxaudioxx xxmtxaudioxx is offline
Ohm out your Injector i have a 1991 with a 2.5 had the same issue now dealing with a low acceleration issue ive replaced Fuel pump Fuel filter injector plugs wires cap rotor rear breaks all because its all origanal on the truck
