Old 02-20-2010, 06:09 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: Demodding nightmare...
Wait, you top swapped back to the stock heads and intakes? How about the harmonic balancer? Did you also take the L67 one off and put the L36 one on? If so, the rubber on the harmonic balancer could be deteriorated and making a knocking sound much like a rod knock. When you turn your car off, do you hear a few slight clunk clunk clunks as the motor winds down?
Inspect the balancer for cracks or breaks in the rubber, and maybe take the belt off and see if it still knocks.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 02-20-2010, 09:53 PM
grandprixgtx00's Avatar
grandprixgtx00 grandprixgtx00 is offline
Send a message via AIM to grandprixgtx00
good thought Tim, but the Harmonic balancer was not changed when i did the top swap originally. Its been the same one the whole time.
Old 02-20-2010, 09:58 PM
finally got the video to play with some sound. here ya go
http://s14.photobucket.com/albums/a3...=Video0008.flv
Old 02-20-2010, 10:24 PM
tblake's Avatar
In God We Trust
Hmmmm, How did you rout a L36 serpentine belt to the supercharger pulley? Just wondering.
Old 02-20-2010, 10:33 PM
tblake's Avatar
In God We Trust
Yikes.
Sounds deeper than a lifter, but not as deep as a rod knock.
If it were my car, I'd remove them valve covers, start it, and touch each one of the rocker arms with it running. You should be able to pinpoint if it is in the valvetrain for sure.
Old 02-20-2010, 10:34 PM
yeah...it doesnt sound good. Just doesnt make sense to me
Old 02-20-2010, 10:40 PM
tblake's Avatar
In God We Trust
I don't know, I'm almost thinking collapsed lifter. Yank that back valve cover off and do like I said above, you should be able to pinpoint it.
Pushrods all went back in the same spots (for wear purposes)?
They aren't aftermarket pushrods are they?
Old 02-20-2010, 10:44 PM
I was not aware you could run the motor with the valve covers off lol.
as a side note...I've been driving the car very regularly now to see if it acts up again. I've been keeping a real close eye on the temp gauge, and it seems to fluctuate a little more than I'd like to see. Even while running at a steady 70MPH on the freeway sometimes the temp gauge will climb up to just under 210, then go back down to around 180.
I'm hoping its not the LIM. I'm not tearing this motor apart again
coolant reservoir is still full...so i dont believe i am loosing any coolant
Old 02-20-2010, 10:53 PM
tblake's Avatar
In God We Trust
you are fine running it for a short time with the valve covers off. I have done it quite often on numerous motors to find ticking/knocking sounds. Just don't want to do it long enough to heat the exhaust manifolds up hot enough to start a fire with the oil that drips onto them.
Old 02-22-2010, 08:03 PM
well...coolant light went on tonight while going down the freeway on my way home from work. Hope this coolant isn't leaking into the cylinders. Didn't see any leaks on the ground. looked around the Fuel injectors and i dont see any coolant. Definitely had to add about a gallon of coolant. If this motor is junk...idk what I'm going to do with this car Oil still doesn't have any coolant in it, I'm puzzled
Old 02-22-2010, 08:32 PM
tblake's Avatar
In God We Trust
what about the upper intake manifold? Did you check for warps before you put it back on?
Old 02-22-2010, 08:34 PM
that is what i am suspecting. Probably an internal leak. exhaust doesnt seem white though, and the car does not miss.
