Old 05-02-2011, 12:06 AM
viggy58 viggy58 is offline
Re: 2001 chevy cavalier overheating
if anti-freeze is disappearing, you have a leak
you need to pressure test the system and find the leak. if you cant find one, you prob have a blown head gasket.
2001 Chevy Blazer
4.3L 5 speed manual
Alpine deck, Type R 12in. sub.
145k miles
1997 Pontiac Sunfire
2.2L automatic trans
146k miles
Old 01-21-2013, 07:05 PM
jamack1 jamack1 is offline
I was reading your posting. I was woundering what was the final out come? Did the problem ever get resolved?
Originally Posted by carnewbiee View Post
I have a 2001 Chevy Cavalier, 66k miles.
The trouble I am having is it is overheating. I start up the car, the temperature gauge creeps to 1/4 mark in a normal manner, goes to 1/2 mark (195 F) normally as well (takes 5-6 minutes when idle) and then starts going past 195 F. I noticed that when I do this with the car idle, the car occasionally sputters a bit around 195 F, as if it wants to turn off.
I have replaced the thermostat.
After replacing thermostat, I refilled the coolant to the top. I noticed that by the time the car got past 195, the coolant level dropped to the FULL line (bit below the top) and didn't drop after.
I never saw any black oil foam in the coolant reservoir. Neither did I see coolant foam on engine oil dipstick. I also don't notice any visible leaks. I don't notice sweet anti-freeze smell. I am not sure about white smoke from tailpipe, I could be wrong but it doesn't really look white to me.
I have bought four new spark plugs to replace, as I plan to do a compression test to check for head gasket issues.
Can anyone think of other (easier) ways to troubleshoot this?
