Old 01-04-2010, 03:55 PM
j cAT j cAT is offline
Re: Oil Pressure 2005 Z-71
Originally Posted by weo38 View Post
Is there a good way to check oil pressure? I am starting to be suspect of the gauge on the dash. I was just wondering if there is a tool or setup I can use to check it.
locate the sender unit on the engine then remove, get thread size ..get fitting to match this thread with a 3ft lenght of tubing to the pressure guage..it don't need be expensive ...any pressure guage that can go up to 100psi will do ...air compressor type...sears//homedepot etc..
then just screw it in and see if it is higher than the dash reading..
if it is indicating a higher reading then install the new sender..this may be the problem..or possibly the connector or the dash unit..
