Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 12-21-2009, 10:23 AM
lixar420's Avatar
lixar420 lixar420 is offline
Re: Car Starts then stalls and POP!
Originally Posted by henry10 View Post
You should not need to use gasket maker. You should get the correct gasket. You should also make sure that things are tightened with the correct torque specs: MAF, TB, IAC (Idle Air Control) valve. 3 questions:
1- Does stalling occurs when engine is hot or cold, or both? its -18 out...
2- Besides the visual check for vacuum leaks, did you actually use a gauge to check for vacuum leaks? no don't have one.
3- Does you accelerator pedal get stuck? nope, still working as it should
commented in the quote ^
Also it is the correct gasket, the gasket maker was just in case for whatever reason the new gasket made a bad seal.
Old 12-21-2009, 08:31 PM
lesterl's Avatar
lesterl lesterl is offline
If you have a bad seal with the gasket then you have issues with something either warped or installed in the improper order/ torque.
Old 12-22-2009, 12:58 PM
henry10 henry10 is offline
Lester1 is right. Keep in mind that air passages need to be sealed properly and any air introduced in the air intake AFTER the Mass Air Flow Sensor causes weird problems. TB is not the place for the gasket maker.
If you want to save money, you should invest in a Vacuum/Fuel Pressure Gauge. They cost about $ 10-15 and you need to read the Vacuum.
You should also answer question 1 in my previous post. That alone will tell you in almost 100% certainty if the Idle Air Control Valve is faulty.
Old 12-22-2009, 06:38 PM
lesterl's Avatar
http://www.harborfreight.com/cpi/cta...emnumber=93547
Here ya go on a cheap Vac guage, something every garage should have.... :-)
Old 12-31-2009, 06:04 PM
lixar420's Avatar
But i don't have a garage i have a townhouse and a big toolbox
Old 12-31-2009, 06:05 PM
lixar420's Avatar
Fixed it throttle body was loose, tip never work on a car at -25 celcius outside things seem tighter then they really are.
Old 01-09-2010, 03:30 PM
lesterl's Avatar
Yeah, no kidding, bet your hands were freezing!!! Glad you figured it out!
Tags
1997 , pop , sound , stalling , venture
