Originally Posted by WMX267
Regarding the TSTAT, I wonder whether it could be defective because I don't overheat. My gauge would go never reach more than 55% of the gauge range, assuming 50% is normal driving temp. How can a faulty TSTAT explain the thumping sound?
Is there a quick way to determine intake and return hoses of the heater core?
As far as determining intake and return hoses of the heater core, I believe the water pump DRAWS the coolant through the heater core. So the hose associated with the water pump would be the return hose. Honestly I never gave the whole situation much thought, so I could be wrong here. If you are asking to determine which heater hose to disconnect to burp the system, I would try the one NOT associated with the water pump.
As far as the guage only going to 55%, The temp guage is not that great. As far as the thumping sound, a lot of strange things can happen when the coolant is not circulating properly.
The things I suggested in my previous post is just what "I" would try in desperation at this point. I would even consider trying it without a thermostat . Good luck and please keep us posted. I'm curious.
