Go Back   Automotive Forums Car Chat > Ford > Freestar
Old 12-07-2009, 07:49 PM
serge_saati's Avatar
serge_saati serge_saati is offline
Send a message via MSN to serge_saati Send a message via Yahoo to serge_saati Send a message via Skype™ to serge_saati
Re: 2004 Freestar (Antifreeze Flow)
which is your engine code exactly?
2003 Chevrolet Impala LS 3.8L OHV
2002 Ford Taurus SE 3.0L OHV (sold)
1998 Ford Windstar LX 3.8L OHV (sold)
2002 Chevrolet Malibu LS 3.1L OHV (sold)
2004 Hyundai Accent GS 1.6L DOHC manual (sold)
1995 Oldsmobile Cutlass Supreme S 3.1L OHV (sold)
2002 Ford Crown Victoria Police Interceptor 4.6L SOHC (sold)
A Windstar without having the check engine light is not a real Windstar.
Old 12-07-2009, 07:50 PM
Originally Posted by userpete1037 View Post
Disconnect the connector to the Voltage Regulator or EGR Valve?
The vacuum regulator.
Old 12-07-2009, 09:08 PM
userpete1037 userpete1037 is offline
I'm not sure what code it is. My fiance took it to an Autozone months ago when the warning light came on and she said that guy in autozone said the code was for the EGR Valve.
Old 12-07-2009, 09:42 PM
Regarding the Voltage Regulator, it is the one that has a connector with 2 pins right? Because when I disconnected it, the car wouldn't come on.
Old 12-07-2009, 09:45 PM
Yes, it's the one with 2 pins.
I'm really surprised that the car doesn't start because of that. It doesn't make sense. Normally when you disconnect it, it should closes and disable EGR... anyway.
Old 12-07-2009, 09:48 PM
Ok well then I had the right one and it won't start when I disconnect it. Do you think the EGR Valve faulty.
Old 12-07-2009, 09:50 PM
No, cause if it was the EGR valve, it will not start at cold and hot condition.
Your only stall at hot condition. It something electronic.
Old 12-07-2009, 09:52 PM
Ok I understand. The EVR is activated with ground, not 12V.
Disconnect is again, but connect the signal pin to Ground. (Not the pin on the connector, the one on the regulator solenoid).
And connect the other pin on the battery.
Polarity doesn't matter on a solenoid.
Old 12-07-2009, 09:58 PM
I'm going to try it tomorrow. I'll let you know what happens. Thanks again.
Old 12-07-2009, 10:14 PM
Well I think I may have mistaken the TPS sensor for thr DPFE sensor. When I said I tested the DPFE sensor, I believe I tested the TPS which is mounted on the front of the throttle body I believe.
Old 12-08-2009, 05:57 PM
Throttle position has 3 pins also and it's a very small black device connected to the intake with the throttle body. So yes, you mistaken it.
So now you will test the DPFE sensor. It's rectangular metallic/black device with 3 pins connector and 2 pressure hose.
Test voltage while engine is cold and hot. Also when engine stall, see if voltage is too low.
Old 12-09-2009, 11:46 AM
If I can gamble on your problem, I bet on the DPFE sensor.
Old 12-10-2009, 10:32 AM
I took it to a dealership and they said I have a shorted CAM Sensor and synchronizer. Is this something I can fix?
Old 12-10-2009, 11:17 AM
Yes you can fix it. Just replace the cam sensor or try to repair the short circuit if possible. Then replace synchronizer shaft of cam shaft.
Look in your service manual in chapter 6 "Emission and control engine systems".
Then go in section of Camshaft position sensor. They explain how to replace it and give a schematic for the synchroniser.
It has 2 sections for the CMP sensor, check the 2nd one for the replacement..
Old 12-25-2009, 06:42 PM
Sorry for the late reply but the CAM sensor was bad and the egr valve was bad. Everything is fixed now. Thanks for all the help.
