Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 12-08-2009, 07:39 AM
ned032002's Avatar
ned032002 ned032002 is offline
Re: 95 rs clutch promlems
Originally Posted by Cavalier9696 View Post
Think I can just cut the rod to match the old one and go with it?
Is the rod bottoming out because it's longer? I would make it so it's the same as the old one but I don't know if they made it longer for a good reason. If the one you bought is a rebuild then it should be the exact same as your old one and there for cutting the the rod will do the trick.
Old 12-08-2009, 08:18 AM
Cavalier9696's Avatar
Cavalier9696 Cavalier9696 is offline
Send a message via Yahoo to Cavalier9696
It not a rebuild. My buddy said the rod being longer is no biggy. He said it is sometime hell to bleed them. I have tried it with leaving the bleeder open. I can here air coming out the bleeder, so does it just take some time? Man brakes are so much ezer.
Old 12-08-2009, 10:03 AM
ned032002's Avatar
If you leave the bleeder open, does fluid come out immediately? I found it easier when bleeding the clutch to use a small water bottle with a hole in the top big enough to put a vac line through. Connect one end to the bleeder and the other put into the bottle, in the bottle put enough fluid in it to submerge the end of the line. I don't know if this is how you do it but it's a bitch if you try to do it the normal way as you do with brakes. Just keep turning the bleeder like usual until no more air bubbles come out of the vac line in the bottle. Use a clear bottle so you can see clearly. This works best for me, lots of trial and error.
