#16
Re: 2003 Windstar losing oil
Exactly
#17
I just checked the line from the PCV valve to the intake and found the rubber grommet/adapter at the intake manifold had a hole worn in the bottom of it where it goes from large to small. It was on the bottom of the grommet/adapter so you could not see it unless you pulled it off and flexed it a little bit. I've tried to seal it with tape until I can get a new one and it doesn't seem to have solved the miss at idle I have but hopefully it will help with the excessive oil consumption.
#18
To see why it use too much oil, check for excessive vacuum at PCV valve. If it's good, check compression. Check also lower intake manifold gasket. Especially if you also loose coolant. For the miss at idle, disconnect MAF sensor. If miss stops, it's either a vacuum leak or a MAF sensor problem/dirt.
2003 Chevrolet Impala LS 3.8L OHV 2002 Ford Taurus SE 3.0L OHV (sold) 1998 Ford Windstar LX 3.8L OHV (sold) 2002 Chevrolet Malibu LS 3.1L OHV (sold) 2004 Hyundai Accent GS 1.6L DOHC manual (sold) 1995 Oldsmobile Cutlass Supreme S 3.1L OHV (sold) 2002 Ford Crown Victoria Police Interceptor 4.6L SOHC (sold) A Windstar without having the check engine light is not a real Windstar.
