Old 10-27-2009, 12:36 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: What is wrong with my truck?
See if he can get a scan tool that will read the sensors data. Look at the Engine Coolant Temperature sensor and the Air Temperature sensor. When they are cold, they both should read just about the same. If one is reading a lot warmer than the other, then that is probably where your problem is. Drive up the road about 5 hours and I can look at it for ya.
http://i153.photobucket.com/albums/s...d1/makers2.jpg
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 10-27-2009, 12:39 PM
tulip010303 tulip010303 is offline
thank you. i wish i knew a decent place to go to where they wouldn't rip us off.
Old 10-27-2009, 05:58 PM
way2old's Avatar
TOKEN HILLBILLY
Ask around. Lots of people that are happy with their shop are really willing to talk about them. Ask your local Better Business Bureau. They might be able to help.
Old 10-28-2009, 07:32 AM
i will. thank you
Old 09-10-2011, 08:08 PM
rockwell rockwell is offline
way2old -
I tried the 3 second solution on my '04 F150 and it took right off. Looks like I'm in the market for a fuel pump. Glad it happened in my driveway.
Thanks!
Old 09-11-2011, 01:53 PM
chamblizi chamblizi is offline
try cleaning your carb/throttle body which ever one you have it could be clogged with grit which is why it refuses to turn over
if you here a sound like it wants to turn over like chrrr rrrr rrr chaa rrrr chaaa rrrrrr most likley its just a dry dirty carburetor/throttle body go to your local auto zone and they can hand you the proper spray needed
Old 09-11-2011, 01:55 PM
another solution is you could have fouled and or dirty spark plugs... as well as fuel injectors once you get it started try some fuel injector cleaner (NOT THE CHEAP SHIT) get the good stuff from autozone (DOLLAR STORE) carb and fuel cleaner is crappy and watered down.
Old 09-11-2011, 01:58 PM
Originally Posted by tulip010303 View Post
My husband and I have a 2004 F150. He replaced the fuel filter several months ago. The truck has 131,000 miles on it. Sometimes it doesn't start. There is really no rhyme or reason. It wouldn't start yesterday morning and it took me 20 minutes to get it started but finally got is started last night. How do I know if it is the fuel filter or the fuel pump? please help me. Also, should we get the fuel injection system flushed? Thank you
never flush always replace save your self the time
like i was saying about the cleaner earlier if the good stuff from auto zone can't clean it then you can hang it up and rest a shore and be sure that it needs new fuel injectors
Old 09-27-2011, 06:44 PM
edford edford is offline
it started this morning after several times. yesterday afternoon it started. it is so strange how it doesn't want to start when it is cold outside.
A garage will put in on a tester and tell what wrong for small amout money take them less then an hour.
Then you know what parts you need, maybe cost 45 - 75 for small garage to test it .
Probably the crank sencer out of adjustment or lose furl injectors if u got fuel injectors
