Old 10-13-2009, 04:54 PM
christian1218 christian1218 is offline
Re: S-10 Blazer stalls when engine is hot
Originally Posted by MT-2500 View Post
The PCM is powertrain control module/computer.
Most good repair shops have the engine capable scanners.
could all this be from the vacume line on the master cylinder? Because on the master cylinder the connector that conects the vacume line to the master cylinder is a round connector that is wiggly and i dont know if they all feel like that.
Old 10-13-2009, 04:58 PM
Old 10-13-2009, 05:46 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
You can pull it and plug vacuum line for a test.
But you will have very little brake.
So do not drive it plugged.
Just for a test.
MT
Old 10-13-2009, 05:57 PM
well i pulled it off and could hear air leaking out while doing it and i havent drove it since yesterday so i think its probally holding good pressure. And the valve in the connector still has spring action so its probally good right? Also its virtually impossible to recreate the problem while not on a test drive. i tried for like an hour yesterday while parked, and ran it the entire time with out a problem but as soon as your driving for 10-15 mins then the problem is there.
Old 10-13-2009, 06:15 PM
MT-2500's Avatar
AF - Advisor
Valve spring action does not mean much.
If you can not hear vacuum leak at it with brake on or off.
And it does not change idle with it pulled and plugged it should be good.
MT
Old 10-13-2009, 07:51 PM
Well i changed the IAC valve and then drove it on the highway for 17 miles then had to slow down for an off ramp and it stalled again. It would not start for about 20 mins. Just turns over but no fire. Usually it will atleast try to fire. I then pulled off the vacume line off the master cylinder and pluged the hole and no change, reatached it and waited about 5 more mins and tried to start again and it fired and drove 1 foot till it died again and so i just left it there and will drive it home tomorrow when its a cold engine again.
Old 10-14-2009, 09:08 AM
MT-2500's Avatar
AF - Advisor
When it stalls you need to check for lose of spark or fuel.
MT
Old 10-15-2009, 07:09 PM
so i dropped the truck off at the repair shop and they are going to run there tests on it tomorrow. When i find out what they find i will post it. They promiced me they would try to duplicate the problems before they do the tests.
Old 10-16-2009, 05:02 PM
so i got the truck back and they said the ignition control module is shot. sho i bought one and gonna go throw it in real quick and hope thats it!!!
Old 10-16-2009, 06:58 PM
So i just took it for a test drive with the new part "ignition control module" and it works like a champ. Thankyou very much on all the help. I really appriciate it.
Old 10-19-2009, 12:23 PM
digimotojohn digimotojohn is offline
Hello everyone, I just wanted to let anyone using our Digimoto 5 software that we have a new release that uses new licensing. We will no longer be supporting the old Digimoto 5 licensing so please email us with your name and old serial number so we can send you a new one. Thank you for your time.
Tags
s-10 , stalls
