Old 09-17-2009, 11:55 AM
ravan17 ravan17 is offline
Re: Yet another supra
what kind of putty are you using? get you some milliput man its great, i actually think it take tooo long to dry, lol. it will give you for ever to shape it the way you need
Old 09-17-2009, 07:00 PM
rebirth215 rebirth215 is offline
Im not really sure what brand it is. Its the only brand he had so i bought it. So I need some wheels do you know where I can get some nice one
Old 09-18-2009, 02:05 PM
I had another slow day at work so decided to work on the supra. The body is starting to take the shape I was looking for. With the body now a little bit wider. I would like wider rims but didnt find any that I like just yet so I started looking through my spare parts and came across a set of R34 rims. I took it and mod it a little making it wider in the rear basicly just added a lip on in and for the front I kept it stock. I didnt have any tires that was wide enough for it so I took some rubber tires from my brother old xmods and slap em on. Tell me what you think
Old 09-19-2009, 12:24 PM
Just a couple more pic of the rims now painted gold. I will be hiting the car with some primer and light sanding if needed and hope to have some color on this thing by monday. as far as wheels i think ima go with Volks TE37. Tell me what you think.
FYI front are stock R34 rims and rear are widen R34 rims
Old 09-22-2009, 12:46 PM
Today I hit it with a couple coats primer and did a little more sanding and then a 2nd coat of primer on but still not smooth yet. How can I get it really smooth? Ive been sanding and sanding but still not smooth. Dose any one have tip or trick for me ??
Old 09-23-2009, 07:37 AM
drunken monkey's Avatar
Razor Sharp Twit
Sanding blocks and sticks.
make your own using small bits of timber.
you'll need about a 2x1 inch flat surface for general large surface sanding and then smaller blocks for well, smaller areas.
you'll also want to nab a bunch of them wooden stirrers from starbucks, cut them into (multiple copies of) a point and glue varying grits (600 and above) so you sand into openings and other difficult to get into areas.
Another shape you'll want is a good 90 degree so you can sharpen up some edges on lips or wing struts etc.
If you really want a complete set, you'll probably want to fashion a few curved shapes too.
For what you're building where there are compound curves, you'll want a cylinder shape.
I've got a whole load of old 35mm film containers that I have fixed sandpaper around the sides of.
Tamiya acrylic paint jars and micro sol bottles are also a good diameter for this.
AF's Guidelines
Read them.
Old 09-23-2009, 09:52 AM
Thanks for the info
Old 09-23-2009, 10:15 AM
Razor Sharp Twit
also, you should think about getting some of these or one of these if you don't already have one.
I also find number 12 swann scalpel blades very useful
AF's Guidelines
Read them.
Old 09-23-2009, 07:00 PM
yeah ive been using the number 11 blade to scrape out door jams and molding
Old 10-16-2009, 11:20 AM
So I woke up yesterday and got a nice suprise in the mail....
I waS thinking about putting the TE37 on the supra but its didnt look right with the wide body so I decided to use the other set.
Supra with 19" TE37
supra with 19" Kranze LXZ
I put the TE37 on a MKIII Supra i waz working on
I am still working on the body of the supra. It still need to be primed again and hit with some color. My next plan is to do a full rollcage and fix the single turbo set up. Please let me know what you think about my work.
