Old 10-22-2009, 08:22 AM
j cAT j cAT is offline
Re: ABS Light On
Originally Posted by ColoradoSilverado View Post
What exactly do you mean by "ABS Grounds" ?
Bert
this would be the return path of current flow from the device consuming power...your vehicle has many ground points..the one I described is a common ABS failure ground ,,,,as well as the fuel pump ground point located by the fuel tank.
did you look at where this is as I described ?
Old 10-22-2009, 07:16 PM
ColoradoSilverado ColoradoSilverado is offline
Re: ABS Light On
No, not yet. I will have lots of time this Saturday to try to fix it once and for all !
Bert
My Truck:
2000 Silverado,, Z71
5.3 Ext. Cab, Long Bed
Original motor + transmission!
As of 3/21/14, I'm at 266,300+ miles!
My wife's Truck:
2005 F150 Lariat CrewCab
(Way nicer them my truck!)
Old 10-31-2009, 01:08 PM
Re: ABS Light On
Finally had some time to look at it some more, the wires from the sensors to the wiring harness are fine, no damage/cuts or anything. Turned out that my digital voltmeter stopped working so I couldn't measure. One weird thing is that the ABS pump runs all the time even when I pull the ABS fuse it keeps running, so I went underneath and disconnected the electrical connectors on the pump and guess what...it still runs ???
Bert
My Truck:
My wife's Truck:
