| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
#16
Re: Vacuum Problem
awesome...looks liek i know wher emy next few paychecks are gonna go lol
thanks! also, that gauge i posted a link for, comes with a o2 sensor, are they universal? or car specific?
Hahn stage IV S16G-Portfueler w/400cc inj-1:1 Aeromotive FPR-Split sec fuel controller-Walbro 255lph FP-240cc inj-Hahn fuel mapper-JE pistons(8.1:1)-Total Seal rings-Eagle rods-ARP studs-AEM filter-C&R radiator-Hahn 3''downpipe & cat-Thermal Eng. 3''catback-LUK clutch & flywheel-Eibach springs-Eibach offset bushings-KYB GR2 struts-Strut bars-Lower rear tie bar-GReddy boost controller-Apexi T timer-Powerslot rotors-Gloshift gauges |
#17
Re: Vacuum Problem
If you're gonna replace the sensor in your car you need to get a setup that will emulate the factory sensor (like the PLX or the LM1). Other than that you just need to add another bung for the wideband sensor.
#18
Re: Vacuum Problem
ohh ok i understand now.
i didnt understand that you add to, not replace the original sensor i get it, so you weld this one in, and it wires straight to the control box that comes with the gauge kit.... cool, thanks!!
#19
Re: Vacuum Problem
This is correct.
98 Eclipse GS Turbo Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio 1981 Chevy Scottsdale 1987 Nissan 300zx - Chump Car 2001 BMW 325i - DD |
#20
Re: Vacuum Problem
silvr, may i ask, what kind of data logger do you use? im shopping online...
#21
Re: Vacuum Problem
MegaSquirt logs everything.
2013 Chevy Sonic 1LZ Daily Driver, 1.4L Turbo, 6spd 75 Monte Carlo SBC 400 6.6L, Aluminum heads, Hurricane Intake... 12 Chevy Sonic 1LZ 1.8L - Traded 01 Pontiac Grand Am SE - RIP 95 Eagle Talon ESi-T 5spd - RIP 88 Oldsmobile Cutlass Ciera- RIP |
#22
Re: Vacuum Problem
megasquirt makes JUST a data logger? bc i already have a means of tuning fuel and all so i just need a handheld logger...
ill look into it when i get outta class today, im late right now, hha but thanks
#23
Re: Vacuum Problem
Partially correct. Many sensors require 36" of pipe before the WB02.
Kris 2012 Genesis Coupe 2.0t |
#24
Re: Vacuum Problem
No megasquirt is the ECU. I log everything thats its doing. If you want to run logs you will have to get an obd2 datalogger since your are piggybacking the stock ECU.
#25
Re: Vacuum Problem
now it makes since...lol thanks man
#26
Re: Vacuum Problem
"Many sensors require 36" of pipe before the WB02"
From what I've seen between 24" and the cat is pretty much normal. Even then you could actually mount it closer if you use a heat sink and if you wrapped your headers it should be mounted further down stream, it all depends on the heat coming through the exhaust. Depending on the mfg the top temp for the uego is somewhere around 800*-900*f, so really it all depends on your car's setup. Also, if you're replacing the OEM sensors you need to place them in the stock location or the AFR will be off and it'll trip a code as the computer is looking for an AFR change within a certain amount of time from adjusting the fuel ratio. |
#27
Re: Vacuum Problem
Never heard of one of these before, did some searching and found a decent write up, here's the link
http://forums.neons.org/viewtopic.php?t=295450 |
#28
Re: Vacuum Problem
damn i was just at lowes today...ill go back this weekend...i can spare 30 bucks to make this little gizmo..even though i cant quite tune yet...
#29
Re: Vacuum Problem
You look stupid as hell wearing them but they work awesome. I actually made some electric ones with a mic and an old computer speak amp. So now I can wear headphones and adjust the volume. Its great. The only problem with the hose is that its hard to turn your head. Get the most flexible stuff you can find and you will be alright.
#30
Re: Vacuum Problem
thats the coolest thing ive ever heard...lol
if you wouldnt mind...whenver you get a free minute, could you go into detail a bit more about how you made the elec. one? id like to make that myself... not to steal your idea or anything lol
