Old 11-16-2009, 10:43 PM
Iflylow's Avatar
Iflylow Iflylow is offline
Re: ARGGHHH! Passlock prob?
Step 1. Have you cut the yellow wire? If not, you will not get the correct resistance. Cut the yellow wire with the car off. Then put the car in reverse with the engine off. Turn the key to start, and while the key is turned, measure from the ignition switch end of the yellow wire, to the uncut black wire. You may have to measure several times, and average the values. The car should not start during this process. I think mine measured about 1500 ohms, but they are all a little different.
Step 2. Attach resistors between the other end of the yellow wire (non-ignition end) and the black wire. The resistors will make the BCM think the correct key is in the ignition switch. After this, any key that will turn the switch will start the car. The ignition end of the yellow wire is not used anymore, wrap it up out of the way somewhere.
You may have to do the relearn procedure after this, I don't remember since it's been 3 years since I installed my resistors.
Hope this helps.
Old 11-18-2009, 04:14 AM
stevie_z stevie_z is offline
Thank you for the explanation! I will try it ASAP and post the result!
Stefan
Old 12-02-2009, 02:33 PM
iflylow & ponchonutty,
you are my heroes! After finally getting a correct mesurement for the resistors (hint: a k near Ohm means KILO; 930 Ohms arenīt the same as 9,30 kOhm, as I finally realized!) it was just a snap: I soldered the resistors in (2 x 4,7 kOhm), turned the key and everything was perfect. It wasnīt even necessary to do the relearning procedure.
Thank you for your invaluable help!
Stefan
Old 12-20-2009, 08:32 PM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Glad to help~
Silverado Ext. Cab 4x4 z71
Pioneer 4900mp
Orion P6.2 Componet sets front
Orion C63 Coax rear
DirectedVideo 9" all in one DVD with surround
2007 SATURN OUTLOOK AWD XR with full entertainment package
