Go Back   Automotive Forums Car Chat > Buick > Regal
Old 08-02-2009, 03:44 PM
3800Regal92 3800Regal92 is offline
Question Re: stalled again!!
i also think i have coolant issues. its not overheating as far as steaming-up or overflowing into the resivior and i'm not adding new coolant on a regular basis but the engine and whole bay area seems extremely hot, i have not tempurature gauge, just a digital dashboard, but i also don't get a dummy light either. seems as if the coolant in the radiator and hoses just sits. the waterpump pulley moves freely, took off the belt and tried to wabble the puley some as if the bearing or shaft were broken but it seems fine. when i changed the thermostat and flushed i did not use alot of rtv sealant so i know thats not an issue.
Old 08-02-2009, 03:46 PM
Re: stalled again!!
do i have to get a steering wheel removal tool to get the column off to get to the multifucn and ignition switches
Old 08-02-2009, 03:53 PM
Re: stalled again!!
this steering SMOKING steering column/ bad switch problem appears to be a common issue
MY CAR:1992 regal custom v6 3.8L VIN#L
the: PRNDod21 (posistion selector i believe.) it has two little dots above the neutral ..
N
does anyone know why?
is it foreign?
Old 08-02-2009, 09:00 PM
Re: stalled again!!
when you had the problem with the switches were you stalling out, what were your sypmtoms?when you changed the switch did it all stop?
i'm trying to trouble shoot this nightmare on wheels
Old 08-04-2009, 10:55 AM
Re: stalled again!!
Anyone know how to take apart the collum on the tilt steering???
The manual states its nearly impossible for the home mechanic. I need to check out the Ignition Switch. I think that might be the culprit.
