Old 07-02-2009, 06:16 PM
Dekeman's Avatar
Dekeman Dekeman is offline
Re: Trans fluid change- capacity??
UPDATE:
Okay, I've added another 12 oz. and am waiting for it to run down the tube so I can get a good reading.
I have another problem now. The stinking oil pan plug that was rounding off will NOT come off. No matter what I use, vice grips, open end or closed end wrench, it's rounding off more and more. I added the trans pan plug, and it ended up a little too close to my oil plug (pardon the cell phone pic):
There's just not enough room to get a 'bolt-off' on there:
You can see how close the two plugs are. I'm not sure if I should drop the pan again, get a new pan and plug and reinstall in another place, or what. I'm not sure how to proceed from here. Any ideas?
Old 07-02-2009, 06:25 PM
Andrew1941 Andrew1941 is offline
I rounded my off one time and the mechanic laughed and pulled out a pipe wrench and twisted it off. Dough! Try a pipe wrench!
2001 3.8L V8 Deathstar with 170,000 KM
2010 GMC Sierra 1500 Crew with 2500 KM
Old 07-02-2009, 08:36 PM
Dekeman's Avatar
Huh! You'd think that being the son of a plumber, I'd have thought of that. Excellent idea!
Old 07-02-2009, 09:30 PM
serge_saati's Avatar
serge_saati serge_saati is offline
Send a message via MSN to serge_saati Send a message via Yahoo to serge_saati Send a message via Skype™ to serge_saati
I hate when it happens.
Try a socket smaller that the original size. And force to grip it. Try both metric and imperial size. It worked for me with my wheel hex bolt.
2003 Chevrolet Impala LS 3.8L OHV
2002 Ford Taurus SE 3.0L OHV (sold)
1998 Ford Windstar LX 3.8L OHV (sold)
2002 Chevrolet Malibu LS 3.1L OHV (sold)
2004 Hyundai Accent GS 1.6L DOHC manual (sold)
1995 Oldsmobile Cutlass Supreme S 3.1L OHV (sold)
2002 Ford Crown Victoria Police Interceptor 4.6L SOHC (sold)
A Windstar without having the check engine light is not a real Windstar.
Old 07-03-2009, 09:34 AM
Dekeman's Avatar
I've never heard of this. When using the smaller socket, do you angle it so it grips?
Old 07-03-2009, 11:24 AM
Erik2002Winnie Erik2002Winnie is offline
you want one barely too sdmall, and you may have tro hammer it on.
Old 07-03-2009, 01:21 PM
Exact. You hit the tool w/ a hummer, so it grip.
No angle.
Old 07-03-2009, 01:22 PM
I mean a hammer.
Old 08-01-2009, 11:47 AM
Dekeman's Avatar
Going in today to put the thing on a lift and get this fixed and finished. I have a fluid pump from Harbor Freight to remove and recover the fluid I just recently added (no use spending another 75 bucks on fluid since it was changed 2k miles ago), drop the pan, hammer on a 'bolt-off' socket to remove the rounded-off plug, then install a new OEM plug and replace the pan (the B&M universal plug kit didn't work out so well- it's leaking like crazy), then replace the trans pan, and fill the trans and oil sump. At least that's the plan. Will post an update later.
Old 08-01-2009, 09:58 PM
Dekeman's Avatar
The job is done and all went well. That little fluid pump rocks!!! I got most of the trans fluid out, but had to use the B&M plug to get the rest recovered from the pan. The pump won't get all of the fluid out. I suppose it would make a pan drop/filter change less messy, but it left so much fluid that I had to open the plug to get more, which left about 3/4 of a quart in the pan. I had some trouble getting the hose to the bottom of the trans; it wouldn't go down anymore. Otherwise it went well.
Old 08-03-2009, 12:45 PM
Dekeman's Avatar
Another thing I wanted to mention is that I pulled out about 9 quarts of fluid when I siphoned out the pan and poured the remaining fluid from the dropped pan. That's how much fluid one should buy when doing a pan drop/filter change. I even lost some when I pulled the filter!
Wiswind's pointer earlier in this thread is true even for my '03- you have to get the fluid level all the way to the top of the dipstick fill area (the crosshatched area) so you don't get slipping on turns when it sucks in air. Don't forget- check the trans fluid level when the engine is to it's operating temp (about halfway on the gauge), on level ground, after going through each gear, and keep it running for the check. Totally opposite of checking your oil.
