Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 06-16-2009, 12:31 PM
gordon_gjs gordon_gjs is offline
AF Non-Newb
Re: Radiator and Cooling Fan Issue
Thanks JCat and Oldblu for all you're help. The car still overheats, so that sucks!!! I think when I get paid I will go ahead and purchase the heavy duty fans that include fan and shroud all in one. As I mentioned before that both fans went out (last year) and instead of replacing the whole unit I just cut the old fans out and zipped tied 2 16inch (I think they were 16inch) fans in place of the other ones. I was also going to remove the radiator and take it get cleaned out (maybe it is still gunked up inside). It is only going to get hotter in houston and I need to solve this problem.
Old 06-16-2009, 01:41 PM
j cAT j cAT is offline
I re-read your posting/issues with this overheating...
did you replace the thermostat,,,with a high quality type...?
replace the radiator/coolant pressure cap,,,,if the system cannot hold pressure you will overheat ,,,this also means any leaks/head gaskets etc...
so a pressure testing of the coolant system is now recommended.
Old 06-16-2009, 02:18 PM
AF Non-Newb
I do not currently have a thermostat installed and the cap is fairly new. Do I need the radiator cap to be a curtain psi rating? I belive I have a 16PSI one installed right now. Well then my next step would be the pressure test.
Old 06-16-2009, 02:34 PM
pressure testing is next....thats good the thermostat is out ,,,very hot by you now...the other thing would be is purging the air out of the coolant system by using that small bleeder valve...
