Old 06-04-2009, 10:36 PM
ukrkoz's Avatar
ukrkoz ukrkoz is offline
Re: Noise from the back?
well, we got that fixed....
.. some hammering involved..
--/ went for a ride some, no noise,,,,
good mechanic i am i guess
(that was my impersonation of Jcat's style)
ok, i got it. was not too bad, just sort of awkward getting some bearing caps out. ahh, hammer and prybar takes care of everything.
one of the old bearing caps was EMPTY - no needle bearings inside at all. none and for long time, was obvious.
packed damn slip yoke with magic grease same time.
those socks i stuck between undercarriage and that whatever -the-purpose-is-shield worked well, now it is REALLY quiet.
once again, thanks for y'all's help.
mike, if it's under load only, then look at the leaf springs bolts attachment points in the frame. i have seen place else pics of those going oval with time, which permits the bolt to start wobbling inside the hole, making noise.
Old 06-05-2009, 08:22 PM
j cAT j cAT is offline
this is not brain surgery...after you do 3 of these and heat the caps first,, so that the plastic bubbles ,,this you could do in 15 min...once you get the technic /tools down....I was shown how to do my first U joint by a pro years ago and I now find this no big deal...mark the shafts so they go back the same...easy on the install so as to not damage the seals...and pressing in the new joints or removal of old don't bend the ears....
