#16
Re: How do you remove rear axles on 2001 Suburban
Once the pin is removed, push the axle towards the diff. The c-clip should easily come out. I usually use a magnet to grab it.
EDIT: Found a picture http://www.nastyz28.com/2gcog/tech/c-clip.jpg //2000CAYukon |
#19
It looks like the clip is really shaped more like a U than a C. That would explain why it could just pull out of the slot with a magnet instead of having to be spread first. Have they ever used a circlip that requires a tool to remove?
#20
Finally got the clips off!
The hard thing about doing this is that all the weight of the clip forces the open side to face you in the diff. You have to rotate it 180 degrees to be able to lift it off with the magnet. It's tough to know when it's at 180 degrees. Also tough to keep it there. Plus you're working through those crossbars. I felt like a dentist trying to extract a tooth. Before I put them back in, I am going to scribe a line on the edge of each clip, so if I ever revisit them again, I'll know exactly where to put the magnet. Removed the four bolts holding the backing plates on. Just waiting for new ones to arrive. Is the axle seal the rubber piece directly outside of the wheel bearing? If so, I'd be dumb not to replace those now, while I can access them easily. Last edited by rs6er; 06-02-2009 at 12:18 PM. |
