Old 10-07-2009, 09:59 PM
cramer_77 cramer_77 is offline
Re: '02 Silverado runs rough..
you might look into the crank sensor, it could be working on going out and just reading funny every now and then.
01 Silverado 2500HD, HID lows and highs, cold air kit, leveling kit, brush guard, dual flowmaster outlaw mufflers, 5% windows.
Old 10-08-2009, 09:31 AM
j cAT j cAT is offline
what happened to the fuel pressure problem? did you get the 53 to 62psi spec..?
whenever a transmission is replaced/rebuilt it is smart to flush out the radiator/transmission coolant lines...also the torque converter needs replacing......what did you do?
Old 10-08-2009, 11:29 PM
shortbed shortbed is offline
Crank sensor is GTG.
Of course the trans oil cooler was flushed and the transmission came with a converter from the dealer.
If it was a fuel pressure issue the truck would run worse when it was under load more so than just cruise speed.It would also set a code if was leaning out this much.When you run it hard it doesn't have any problems,only time it happens is at moderate speed/part throttle.
Did a road test with the Modis and there were no misfires and TCC looked ok.No codes present either.
Guess I should change the title to Driveline shudder instead of running rough
Old 10-09-2009, 12:36 AM
theclutchmart theclutchmart is offline
Not exactly familiar with the 5.3, but if it is low pressure and not the fuel pump, then I'd check the fuel pressure regulator if there is one. Hope this helps!
Unauthorized advertising link removed by Moderator
Old 03-20-2010, 12:01 PM
DennisG_02Silvy DennisG_02Silvy is offline
did you ever get the problem resolved? (driveline shudder)
my vehicle has been having the same problems.
