#16
Re: 95 blazer won't start
i tested it with an OHMs tester if you get a chiltons manual it will tell you the readings it is supposed to put out. you can test it with the dist still in. just take off the cap and disconnnect the ingniton module. you should be able to test itt right there. Oh and if you can get your hands on a manual let me know i will write esxactly how to test it.
so i havent had a chance to look at the car in a couple days, it's a good thing that i have a spare truck for her to drive. here is a quick question. since i think the timming is just a little advanced can i just try to turn the dist slightly? and if so do i turn it counter clockwise? |
#17
so after drilling and tapping the air penlum it is now putting out the right amount of vacuum presure (17-22 psi) so i took your advice mt-2500 and fixed the only problem i knew was wrong and adjusted the timing. I didn't do it the proper way i just had someone start it and slowly turned the dist untill it started running right.
well thank you for your help. now it's time to move onto my next project
#18
You can not get it timed right by ear.
Do the proper procedure. Good luck
